928 Forum 1978-1995
Sponsored by: 928 Specialists
Help ! Sudden No Auto Gear Shift
Old 10-16-2012, 08:50 AM
  #106
MainePorsche
MainePorsche's Avatar
With helper, I attempted to rotate both wheel forward while in Park. This was not possible. Felt like we were playing 'tug o war'. When switched over to Neutral, both freely rotated forward with helper rotating my opposite side.
Old 10-16-2012, 08:56 AM
  #107
Pagnobito
Pagnobito's Avatar
Looks like most are trying to have you test if the drive from the box to the diff is broken, hence turning both wheels in the same direction or one off the ground. You need to do that before going onto anything else. Edit, my post crossed yours, I see you just did that so -
If the selector is unobstructed through the movement and the selection switch on the gearbox is working properly you may have no modulating pressure at all from the governor.
Hard shifts are usually a bad vacuum connection (no vacuum at all is very hard shift) and you adjusted the pressure, which shouldn't really need doing unless there is another problem. Have you checked vacuum at the tranny end?
You can swap out the modulator without dropping the tranny if that is suspect.
Old 10-16-2012, 09:08 AM
  #108
MainePorsche
I was going to check if the modulator held pressure and check the vac line the weekend when this occurred (this event unfolded on Friday afternoon). From what some have said, even No vacuum would not cause this (?).
Old 10-16-2012, 09:12 AM
  #109
Pagnobito
Pagnobito's Avatar
Correct, no vaccum, you will still get shifts, but shifts like you are at maximum throttle all the time. But if you have no vacuum and a bad modulator, I don't know what symptoms would show. I know the former from experience.
Old 10-16-2012, 09:14 AM
  #110
MainePorsche
And the beat goes on...
Thanks.
Old 10-16-2012, 09:18 AM
  #111
Pagnobito
Pagnobito's Avatar
Does the car start if you select anything other than P or N? (it shouldn't) but make sure the brake is on in case.
Your most likely culprit after the other tests you have done and has been pointed out before is the modulating pressure is insufficient, this should be your first point of diagnosis now.
Old 10-16-2012, 09:27 AM
  #112
Kevin in Atlanta
Kevin in Atlanta's Avatar
I had something like that happen to me while driving my 86.5 with a 89 A/T. I was poking along in traffic and lost all forward gears, coasted to the break down lane put it in park. Moved the selector through all the gears and when I put it in drive I was able to drive away. Never repeated itself. I assumed it was dirt in the valve body.
Old 10-16-2012, 09:29 AM
  #113
MainePorsche
The Car does Not start in Drive.
Will address the pressure scenario today.
Thanks again.
Old 10-16-2012, 12:52 PM
  #114
76FJ55
76FJ55's Avatar
This would indicate that the park function is opperating correctly, which is in contradiction to the original condition. At this time if the rear is still on stands i think i would start the car and run it back through the gears and see how it reacts.
Obviously the root cause of the issue hasn't been determined, but the conditions now seen to have changed.
Old 10-16-2012, 12:58 PM
  #115
MainePorsche
Simon,
Put it in Drive and (I could only get to see the L rear) she was trying to move. It would move several inches, then stop, then a few less further. I gave it gas and it would do the same. That's a first since it's been on stands.
Old 10-16-2012, 01:21 PM
  #116
76FJ55
76FJ55's Avatar
Try idling it in drive and getting out and looking at the right rear and see ir it's spinning. Ir set up a mirror so you cann see the right fron the drivers seat.
Edit that should have been "right" I corrected it.
Old 10-16-2012, 01:52 PM
  #117
MainePorsche
Sorry, had to step away for a bit.
In Drive again and the L would only move a few, then stop, move a few, then move no more. The R never moved. Funny in Reverse no movement, but if I helped it, it would spring back forward to its original position.
Old 10-16-2012, 02:01 PM
  #118
Pagnobito
Pagnobito's Avatar
I'm not saying ignore everyone, but you are not really gaining anything right now by seeing if wheels spin.
You said the ATF level is good (so TC is not drained). I'm not sure why the car rolled when you put it in park, but the previous wheel turning test seems to indicate the park lock is good. If something in the drive broke you would have heard it.
You have major slip in all stick positions, the WSM manual is clear on this - modulation pressure.
Let us know what you find.
Old 10-16-2012, 02:22 PM
  #119
the flyin' scotsman
the flyin' scotsman's Avatar
Perhaps if the modulator was going it prevented the park pawl form engaging?
Seems we're getting closer
Old 10-16-2012, 02:24 PM
  #120
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by Charley B
Hasn't this been addressed a few times when he says he put the car in park and it began to roll downhill?
Yes, but that is a very important detail and I need to make sure that is correct. It's difficult to diagnosis things, from afar, especially when all the details don't add up.
If you read his post #106, the fact that it rolls downhill, in park, is apparently not correct.
Quick Reply: Help ! Sudden No Auto Gear Shift
