Help ! Sudden No Auto Gear Shift
#271
Former Vendor
Bertrand,
I would have liked to have done the TT bearings, but I am at the tail end of a catastrophic matter which has caused much fiscal pain. These bearings will have to wait. I was fortunate enough to be able to get the transmission. It is one of Greg's 'new' ones that he found in a warehouse in Germany. This new unit is from the torque tube to the rear axles so I imagine the TC seal will be good to go. As I get the experience of dropping the rear end now, I was thinking of Constantine's Super Bearings when I'm completely on my feet, and putting in Bilsteins all around. So far no signs of bearing dysfunction, but I am cognizant of them.
Thanks again,
Craig
Thanks again,
Craig
This one will be yours:
![Name: DSCF1671_zps05da7d36.jpg
Size: 86.4 KB](https://rennlist.com/forums/attachments/928-forum/1236132d1501791993-help-sudden-no-auto-gear-shift-dscf1671_zps05da7d36.jpg)
This thing hasn't seen the light of day for over 25 years!
![Name: DSCF1673_zps068d1ed2.jpg
Size: 86.2 KB](https://rennlist.com/forums/attachments/928-forum/1236133d1501791993-help-sudden-no-auto-gear-shift-dscf1673_zps068d1ed2.jpg)
Free, at last, free at last.
![Name: DSCF1672_zpsa2be3ae0.jpg
Size: 70.9 KB](https://rennlist.com/forums/attachments/928-forum/1236134d1501791993-help-sudden-no-auto-gear-shift-dscf1672_zpsa2be3ae0.jpg)
Factory markings.
![Name: DSCF1674_zps3b8441d4.jpg
Size: 87.8 KB](https://rennlist.com/forums/attachments/928-forum/1236135d1501791993-help-sudden-no-auto-gear-shift-dscf1674_zps3b8441d4.jpg)
All of this means that there is a brand new 40% limited slip, hiding behind that cover.
#273
Former Vendor
Craig:
More pictures:
![Name: DSCF1675_zps7c49ef4b.jpg
Size: 86.5 KB](https://rennlist.com/forums/attachments/928-forum/1236136d1501791993-help-sudden-no-auto-gear-shift-dscf1675_zps7c49ef4b.jpg)
This one, to be exact.
![Name: DSCF1676_zps26e1fb58.jpg
Size: 56.6 KB](https://rennlist.com/forums/attachments/928-forum/1236137d1501791993-help-sudden-no-auto-gear-shift-dscf1676_zps26e1fb58.jpg)
Clean and use new gasket.
![Name: DSCF1677_zps4da6327b.jpg
Size: 90.5 KB](https://rennlist.com/forums/attachments/928-forum/1236138d1501791993-help-sudden-no-auto-gear-shift-dscf1677_zps4da6327b.jpg)
Install cover.
![Name: DSCF1678_zpsdb93ab09.jpg
Size: 98.9 KB](https://rennlist.com/forums/attachments/928-forum/1236139d1501791993-help-sudden-no-auto-gear-shift-dscf1678_zpsdb93ab09.jpg)
Torque hardware
![Name: DSCF1680_zps5daebd87.jpg
Size: 75.3 KB](https://rennlist.com/forums/attachments/928-forum/1236140d1501791993-help-sudden-no-auto-gear-shift-dscf1680_zps5daebd87.jpg)
Pretty clear?
More pictures:
Install cover.
Torque hardware
Pretty clear?
#274
Wow !
Thanks Greg. I'm lining up my workspace, and some trans. jack equipment from a friend in the trade (Big Trucks - Ryder Inc. service shop).
Can't thank you enough for having such a thing... though not surprised.
#275
First the stroker **** pics and now these gbox beauties.....very very nice.
Your onto something special Craig...........we watch on in envy........pls take and post many pics
#277
Former Vendor
I don't want anyone to get one of these transmissions, from me, and have any problems. I'd rather spend a few hours and buy some parts, to make sure everything is as perfect as it can be. I'm trying to update them to the latest and greatest pieces, plus replace a few gaskets and seals, so I know they will not leak.
Now the "other" end:
![Name: DSCF1681_zpse34ef1aa.jpg
Size: 84.0 KB](https://rennlist.com/forums/attachments/928-forum/1236141d1501791993-help-sudden-no-auto-gear-shift-dscf1681_zpse34ef1aa.jpg)
Bolts removed from the convertor bell housing and the flex plate.
![Name: DSCF1684_zps285b32e2.jpg
Size: 85.8 KB](https://rennlist.com/forums/attachments/928-forum/1236142d1501791993-help-sudden-no-auto-gear-shift-dscf1684_zps285b32e2.jpg)
Remove housing and convertor.
![](http://i1033.photobucket.com/albums/a415/GregBBRD/DSCF1683_zps9a7b8a80.jpg)
Remove oil pump/B3 piston assembly.
![Name: DSCF1685_zpsde8d1ef4.jpg
Size: 82.3 KB](https://rennlist.com/forums/attachments/928-forum/1236143d1501791993-help-sudden-no-auto-gear-shift-dscf1685_zpsde8d1ef4.jpg)
That's what is inside, once the pump/B3 piston assembly is removed.
#278
Malcolm, thanks for your support throughout.
Still not at the end yet, but I think no more mysteries.
#280
Team Owner
Good luck on installing the new trans its beautiful
#282
Well, thought this would be a good time for the UPDATE to this thread.
After much to do, I installed one of Greg's 'new' 0.4 LSD transmissions.
Car is now running the way it was meant to be.
Again, Thanks to all.
#284
