Help ! Sudden No Auto Gear Shift
#241
Really, thanks for thoughtful attention.
#242
Former Vendor
That I can not predict. Totally depends on what I'm doing, at that particular time. Mary will let you know, when you call. You have to tell her who you are and what you want, to even have a chance of getting through, BTW. She's my "phone filter".
#244
Former Vendor
#246
If Greg takes your core that would be the best way to go. Assuming you can afford it.
#248
#249
This car means much to me, and I treat it that way. I've never changed a transmission, but I would like to see my gems life prolonged.
I will email and try to catch Greg at the shop.
Thanks again Jim.
#250
I have an 87 auto with LSD for sale if you need one.
#251
Guys,
Just put the order in for one of Greg's 'new' transmissions.
Please feel free to post tips, pointers, etc. regarding everything from take down of the rear axle (especially the CV units), to the take down and refit of the transmission itself.
Thanks,
Craig
Thanks,
Craig
#252
That is awesome!
#255
Be sure to mark the location of crossmember to body and eccentrics to body. You can use a paint marker on cleaned surfaces. Then realign to marks upon re-install.
Make sure transmission is secured to the jack when lowering/raising - it will tend to roll off. A transmission jack with a tilt platform makes this job a lot easier.
Some good write-ups should return from a search. Good luck.
