Stroker timing problem
Could be due to a weak mixture - check temp 2 sensor at pins 13 and 5 of the LH 35 way connector.
Should be in the range 2000 -3000 Ohms (2-3k ohms). If it measure short or open circuit then the LH defaults to normal engine temp fuelling which will be much too weak for a cold engine.
I may have missed this , but have you checked that there is correct fuel pressure at the injector rails , if it fires and wont run sounds to me like there is no fuel pressure .
I would remove the fuel pump relay , and bridge the connection enabling the running of the pump , you should here the pump running .
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Hammer
OK wont run , saying that the injectors are not firing , they are turned on after the ecu detects that there is a crank pulse , is there are crank pulse, you may need a cro to determine this , unless the ST will detect pulse width or crank angle, it has been a while since I have used the ST so I cannot remember , JS should be able to answer this , fronm what I remember the diagnostics are quite good in determining what is not happening .
The problem likely lies with the wiring that has been done.
Hammer has stated that the 88 harness has been plugged straight in without any modifications. This doesnt work.
So here is the information needed.
1985-86
W11 - tach and electric kickdown
W12 - from EZF to fuel consumption guage.
W13 - power from fuel pump relay for switched +12V signal to injectors, and heater for O2 sensor.
W14 - EZF power from relay
W15 - fuel pump activation
W21 - LH relay activation signal from EZF +12V
W22 - power to LH while cranking. <-- Diagram shows this to be ground, but I am 99.9% positive it is +12V, this is also activation line to the starter, output Q13.
W23 - LH power from relay.
W24 - LH pin 16 to instrument cluster (low pressure switch, and thermoswitch. Possibly to shut down the engine when low oil pressure, or overheats)
W25 - timing belt tensioner system
These are the pinouts on the 1988 fusepanel.
1988
W12 -
W13 - Power from LH relay to fuel injectors +12V
W14 - EZK power from relay.
W22 - Constant +12V to both LH and EZK
W24 -
So with this information you can clearly see that the LH/EXK are ONLY getting power while cranking.
To fix this, remove the W plug from the panel, you will have a yellow piece on it with some ridges, this is what ensures it only gets plugged into this location. It is on the right. just to the left of this piece you have 5 wires, W21 is bottom, W25 is top.
the 5 wires to the left of that is W21 (bottom), to W25 (top).
You need to either separate the plug and remove W22, or just cut this lead, and make an attachment. This lead will then need to be bolted to the top of the fuse panel where the battery cables come into the car.
Once this is done, the car will run.
1985-86
1988
W12 -
W24 -
When I've done these conversions ('85/'86 using later motronics), I've had to add relays to the fuse panel and change some wiring. I've got lots of notes regarding how to do this, but as I recall, there was an issue (on the '85/'86 relay board) with one of the relays only getting triggered when the engine was cranking and I had to change the wiring so that the relay had power after the key was "released" to the "run" position.
I went back into my notes. Very expensive!
Although it has been a few years since I had to do this, it looks like the W22 wire on the '85/'86 vehicle is powered only when the starter is turning. From there, it goes to the #4 connector on the LH....which is not connected on the '85/'86 car.
For the '87 and later brains, there has to be constant "30" power to the #4 connection to the LH computer. Therefore, W22 has to have full time power.
My notes tell me that I changed this W22 connection to have "full time "30" power.
This seems to make sense with what you are saying is happening? Runs only when the starter is engaged?
Regards, Hammer
