928 Forum 1978-1995
Sponsored by: 928 Specialists
Stroker timing problem
Old 08-16-2012, 12:48 PM
6.0-928S
6.0-928S's Avatar
Default Stroker timing problem
Hi folks, It's been a while since I've been on, I had another major eye surgery & I'm still not done yet. But anyway, I'm having trouble getting my stroker to start. It seems like the spark timing is too advanced. I hired a local Porsche factory tech & race team crew chief check my assembly. All the mechanical timing marks line up perfectly, we have spark & fuel. But when we try to start it it backfires flame out the intake. Since the spark timing isn't adjustable we're confused. Has anyone had this happen or does anyone have a suggestion?
TIA, Hammer
Old 08-16-2012, 01:48 PM
fbarnhill
fbarnhill's Avatar
Sorry Hammer, I can't help but I can't believe you have a 65 Hemi Belvedere. In 1972 I had a 66 Hemi Coronet in NC. I got a funny ticket one day by finally catching up with the only other Hemi of the period that I knew about which was a 65 or 66 Belvedere. We were on a 4 lane road (45mph) and I finally caught up with him without too much traffic. So, I am reving my engine to get his attention, He just laughs and points behind me. There were blue lights everywhere. They got me for 55 in a 45 while trying to catch this guy. Lucky for me the cop didn't wait a few more minutes...LOL... I will never forget it. Hard to believe but that coronet was one of the best handling cars I have ever driven. Not to mention the TORQUE ... Mine had the 426 with 2 4s, Dana rear end and 4 speed. For a while I raced it every weekend at the drag strip and it was my daily driver. God, I miss cheap gas!
Good luck with your 6L. I hope you will post a sound byte when you get it running. Do you have the stock mufflers on the Hemi? Mine had them when I first got it. The only clue you had were the emblems on the side and the muffled rumble at the rear...
Old 08-16-2012, 02:24 PM
dcrasta
dcrasta's Avatar
PICS of the Hemi.
Whats your static timing set for? what happens when you retard it slightly ?
Old 08-16-2012, 02:49 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Basic: Fuel pump fuse pulled so no fuel available. Put a timing light on the #1 plug lead and see what te timing is like while cranking.
Basic: Verify that the timing marks on your damper coincide with TDC on cylinder 1. Remove the spark plug, and move the engine by wrench to just before TDC on the damper. Long pencil or wood dowel in the plug hole. Watch the pencil/Dowel as you slowly roll the crank through and past the TDC mark. Did the motion of the dowel crest at thr TDC mark on the damper?
Then verify cam & valve timing against that TDC mark. PorKen's 32VR tool is handy for getting cam timing just right. If cam timing is off, you risk the backfiring symptoms you describe. If you replaced the cam chains in the haeds, there's another opportunity to get one of the cams in each head timed wrong.
A simple compression test is a gross detector of cam timing problems. Low on one bank is a telltale.
Old 08-16-2012, 02:50 PM
6.0-928S
6.0-928S's Avatar
The timing isn't adjustable. It's set by the ECU.
Old 08-16-2012, 02:53 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,777 Likes on 1,351 Posts
What's the engine management hardware on this beastie? I poked around in your old posts but couldn't find anything.
Mike Simard
Mike Simard's Avatar
I'd take the valve covers off and verify valve timing on #1 and #6
Old 08-16-2012, 02:58 PM
6.0-928S
6.0-928S's Avatar
Dr Bob, We spent a few hours doing that last night. I used the Porken tool when I degreed the cams. Compression was 195 on all cyl's on one bank & all were 205 on the other.
Thanks, Hammer
Old 08-16-2012, 03:29 PM
6.0-928S
6.0-928S's Avatar
Rob, At the moment it's the factory ECU's. I have a shark tuner but when I install the STII PEMs I don't have spark so we were trying to get it to start first & then check with John to see why I have no spark with the PEMs installed.
Hammer
Old 08-16-2012, 03:48 PM
OBehave
Former Vendor
OBehave's Avatar
+928! This is mandatory if you are running aftermarket or reground cams. I have Devek B2 cams in my stroker and when timed with the porken tool the car had BIG issues. The Porken tool is a great help but it MUST be calibrated and checked against the old fashioned way of valve cover of and dial indicator installed.
What cams are you running? And did you triple check the parkplug wire routing?
Ed
Old 08-16-2012, 04:17 PM
Cosmo Kramer
Cosmo Kramer's Avatar
Ed
+1 This one bit me in the *** one time.
Old 08-16-2012, 04:24 PM
6.0-928S
6.0-928S's Avatar
Ed
Yes. we triple checked the wires. It has reground cams. But I did set them with the dial indicator. And checked 4 times & got the correct readings. Checked it, rotated the engine 9-10 revolutions, checked it again.....etc.
Hammer
Old 08-16-2012, 04:58 PM
Mike Simard
Well it's either valve timing or spark timing out. Maybe it would help to look at it as though you haven't checked anything yet.
First verify your damper degree marks are good
Check cylinders 1 and 6 both intake and exhaust opening at 1mm or whatever it's supposed to be checked at.
Blow some air into each cylinder when valves are closed to verify that valves are indeed closing.
That leaves the spark. What does a timing light say while cranking? It's wasted spark so you don't have to worry about being one revolution out. It's theoretically possible but unlikely for the crank to have been miss drilled or a flywheel that had a timing ring added to be off.
Have those parts run in another engine?
Old 08-16-2012, 05:02 PM
John Speake
John Speake's Avatar
Good to see you back working on your 928 project !!
You haven't worked on the Flywheel /timing ring, have you ?
Old 08-16-2012, 05:13 PM
6.0-928S
6.0-928S's Avatar
Mike, the damper is the ATI Super Damper we got together on remember? The flywheel was used & I didn't modify it.
I guess I'll have to pull the cam covers & do the dial indicator again.
John, I get no spark with the ST II PEMs installed. I had to put the OE chips back in.
Thanks, Hammer
Quick Reply: Stroker timing problem
