camshaft large O ring, is the the correct fit?
trying to get the car put together and the O ring I got seems mighty narrow for the space provided. Should I have this much space? The O ring I removed filled the gap although it was likely flattened a bit.
Former Sponsor
Two different o-rings, for that application.
I'm not at work to look up the two part numbers, but that is not the right one.
Do not proceed!
Do not proceed!
Archive Gatekeeper
Greg, is this the pair of o-rings in question?
What I have according to the package is PN 999 701 425 40, item # 10 in the parts manual.
It is narrower than the O ring that was on my camshaft - see pic below, Oring on the left is new versus right is what was installed. Of course that does not make it right has my oil pump had no O ring's around the bolts
Former Sponsor
Yes, Edwards to the rescue, once again.
Number 10....two different o-rings.
One is 4mm x 52mm and the other is 5mm x 50mm.
You need the 5mm x 50mm version.
You install the 4mm version and you will think your engine was built at Rainbird.
Former Sponsor
If someone is in a big hurry, I'd suggest for them to have both sizes available when they take the engine apart.
Basic Sponsor
If you look at PET it states that the thinner ring is suitable for M28/1,2,3,4. No reference to VIN/Eng # split. Thickness and diameter changed significantly.
The smaller O ring used at the spacer changed early in 78 (ref: TSB 78-03). No reference in that TSB about the larger O ring. Cam part numbers changed to 155-07 & 156-07.
Found it TSB 78-04 11/1/78 - O ring changed to larger diameter - From Engine number = 5 speed Eng #829 0252 and Auto Eng #829 5131.
Basic Sponsor
Cam Shaft O Ring 77 to 78 small 999 701 452 40
999 701 452 40 up to Eng # Manual 828 0081 & Auto 828 9025
Cam Shaft O Ring 78 to 86 small 999 701 592 40
999 701 592 40 from Eng # Manual 828 0082 & Auto 828 9026
Cam Shaft O Ring 78 to 79 large 999 701 425 40
999 701 425 40 up to Eng # Manual 829 0251 & Auto 829 5130
Cam Shaft O Ring 80 to 86 large 999 701 602 40
999 701 602 40 from Eng # Manual 829 0252 & Auto 829 5131
