How to best dyno a 'Roger box'?
Looking forward to receive advise on what to do, so to best dyno my 4-speed automatic. This as very soon I will make a local appointment so to be able to get before- and (than after a few days) after-modifying results (as I'm very interested in the delta, less so in the absolute numbers).
Just put it in D an floor it, or making some prepations or...?
The dyno will be of the type that is directly attached to the wheel-hub, so not the more tradtional rollers type of dyno.
Eh...I'm a total 'noob' regarding dyno's (hence my question), the dyno tester is of this type's: http://www.rototest.com/
Also run the test in 3rd gear......4th (2.20) is far too tall for most dyno's....my 84 with its brutal 198whp pegged the dyno at 195mph.....
If you have a 3 speed then 3rd is fine since its the 2.75 and will "only" hit 160ish mph
I think forced 3rd gear is needed or dynos speed limit is reached before redline even with 2.54:1 diff. Will selecting 3rd do the trick together with killing kickdown switch and cable to the gearbox? I'm also interested as my automatic GTS and maybe some other 928 automatics will go into same dyno eventually.
There is a similar bit about kick-down causing a 3rd to 2nd down-shift at anything less than some lesser speed, but I don't have the actual numbers handy.
Without the kick-down disconnected, I am tipping that the 'box will downshift if you floor the throttle at typical dyno run starting speeds.
I am guessing that two gear shifts (3 to 2, 2 to 3) through a dyno pull would invalidate the readings somewhat.
Dyno-run with 1994: also remove dynamic kick-down relay XVII?
Having a 1994 with dynamic kick-down and going for my base dyno-run tomorrow 10th August 2012, is it better to also remove the dynamic kick-down relay XVII?
I have been checking the electrical wire diagram for MY 1994 on this, however not entirely sure - so any further advise of those of you who have done dyno-run's with MY 1994 or 1995: much appreciated!
5th manual/4th auto would be better, with a 1:1 ratio, but you are getting close to 200 mph.
Make sure your tires are in good shape! Flat tread, no alignment problem wear.
No need to also unplug the kick down switch under the gas pedal, as that is in series with the dynamic kick-down relay switch.
I will open a separate thread for my dyno-shop findings (having just returned from it): that was fun and I learned several things!
