LSD problem....what happened???
Yesterday on the track my "no shift O' matic" racer was running well (other than not being able to shift gears).....I noticed a HARD bottoming issue at over 100mph in turn 8 (fastest corner on track) so we raised the suspension by 10mm.....car was handling GREAT......felt awesome I was chasing some miati and all of sudden my LSD let go.....I couldn't turn hardly at all, it was like an open diff....anything more than 1/3 throttle while turning was a joke....![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
endless Bill Ball impressions....
SO here is my question to the forum....WHAT HAPPENED....you can watch my previous video literally 1 hour before where the car worked well (I posted a thread)...and watch this....night and day difference.....so what was the cause?
I KNOW.....my mechanic called me today (he lives near the track)....
What say yee
What say yee
That is exactly the behaviour I got in a race car I had which regularly snapped axles. It became a real handful, with massive throttle steer, and wanted to swap ends at every turn.
What broke was the front sway bar.....its a DEVEK bar and it snapped on the passenger side right where the threaded part goes into the bar itself...
I plan on installing a weltmeister bar I have.....then I can take time to fix the Devek bar
This LSD was weak from when I got this car.....I have slowly been taken steps to improve the function of the LSD.....lower ride height, reduce rear bar, disconnect rear bar, add friction modifier to the rear end oil...all of which made things progressively better....then it was like I literally hit a switch and was worse off than I ever have been.....
Its getting there.....just a matter of time to sort out the car to make it the way I like.....of course I like shifting gears.....I think this trans might have an internal problem with 4th....at any type of real load its nearly impossible to get 4th....only can get it with very low rpm under light load....
Interesting.......while the LSD is VERY weak, the axles are fine....
im running 3/4 stiff now on a devek bar. seems to help but would like to have 50 to 100lb stiffer springs. (775 x 450). full stiff would pull the brackets apart that hold the lower bushing bolt. reinforced, it holds , no problem, even full stiff.
