New 928 Owner Intro
Car was hit on passenger side necessitating front bumper cover and fender replacement. It was light front corner. No signs of anything more serious
Thanks! Its badged that way but its not an "S". Its the competition package. I will be assessing it more in depth this weekend. Need to undo some previous electrical mods to be able to start from a clean slate with diagnosis.
There is a lot to do and despite some previous comments, I don't think it will just buff out I started with replacing the negative ground strap with what appears to be a good used strap. The previous owner had a really poor looking strap grounded to the rear wiper moter mount. I cleaned the factory mount (it had been painted over at some point) and reinstalled. I don't want to juice it yet, too much wiring jacked up. I am going to address the front "jump" post and the connectors next. Slowly but surely....
I am trying to get this car to a good starting point before trying to diagnose all its issues and needs. Someone has really jacked up the wiring, probably in an attempt to diagnose the "no crank" condition. I have yet to even power it up for fear I will do more damage than good. So I corrected the ground at the battery box and have moved on to the next issue: The 14 pin connector or whats left of it!. Someone has previously attempted "repairs". I am actually considering pulling the engine harness to properly repair it.
While I am typically a stickler for originality, this car is a mess and until I know more about it, I don't want to throw money at it quite yet (that time will come, but not until I at least hear it run). I have sourced a Mercedes 14 pin connector (free) which is basically identical except that it is slightly more robust than the Porsche unit. Going to get this all sorted and move on from there....
could be getting yourself into a lot of rewiring time for nothing.i say drop a battery in,connect it up cautiously and pull the trigger.were on the edge of our seats here!
Shameful Thread Killer
The plug is nasty bad and most of it is gone. My preliminary check shows that the plugs are not even in the right locations. The 14 pin connector is currently only 12pins as it is so cracked up. Granted, I could jump the yellow and see it if cranks and that's probably not a bad idea. I will probably try that tomorrow. Can I do this with the 14 pin connector disconnected? Again, I have serious doubts about whether the pins are placed properly. The colors are not 100% accurate due to previous repairs.
I used a jump pack and touched the male end of the yellow starter wire to the jump pack. Nice strong "click" like the starter solenoid is engaging but the starter did not turn the engine over. I have not checked connections at starter itself. I am kinda jumping ahead of myself. Suggestions?? Any and all help appreciated!
Weak batt, bad primary wiring to starter, or bad starter. Have you tried to turn the engine by the nut on the crank pulley? I hope it's not seized.
Okay, that makes sense. So in theory, with a battery in place, ignition key on, touching the heavy yellow starter feed should crank the engine?
