My 1991 GT with Factory GTS Flares!
#31
Hi Cheburator , I have figured out what you saw , the 17" dia Cup 1 wheels on the 968 you mentioned are the very rare 8 J X 17" X 52mm winter use only wheels ( rare option ) and only for use with winter tyres , well thats what Porsche wanted & they are even wrong for a 968 with summer / normal tyres .
The Porsche supplied 968 ( summer / normal ) 17" dia Cup 1 wheels ( option only in 1992 & 1993) are as stated above , 7.5 J X 17" X 65 mm offset ( fronts ) which are the same as a 928GTS & the rear wheels in Cup 1 are the same dimensions as a 928GTS ( hence why we buy them ).
In 16" dia the standard ( Non M030 ) front wheels on a 968 are 7 J X 16" X 55 mm offset ( same dimensions as a non M030 944S2
In 1994 , the 968 clubsport ( with M030 ) = different front spindles & 928S4 front brakes had Cup 2 wheels , and again in the 7.5" X 17" X 65mm off set ( same as a 928GTS ) ditto for the rears ( same as GTS ) .
#32
This car is now in my garage after a five year chase. My understanding is that the XX8 option refers to the Widebody. Time will tell as I move forward with more research.
911user (06-08-2020)
#33
I have factory info someplace that claims the 1" wide flairs of the GTS were new to this model.
#34
Well, if that's what you wanted, congrats!!
I have seen one other in person in Europe. That one was certainly factory equipped with GTS fenders. So, it is possible that yours was as well. The CoC suggests that and it seems to be proof enough to me at least.
#35
Id like to see those front fenders closer on the purple car.
#38
