928 Forum 1978-1995
Sponsored by: 928 Specialists
New to 928!
Old Aug 12, 2012 | 01:18 PM
  #271
landsharklady's Avatar
landsharklady
I was going to see if the starter could be tested when it goes in for the other bits.
Old Aug 12, 2012 | 01:25 PM
  #272
landsharklady
My birthday list goes
Multimeter
Ramps
A pony.
Old Aug 12, 2012 | 01:28 PM
  #273
landsharklady
Car has heat Shields? (not sure what they're actually called) underneath.
I was hoping as engine ground is to the side I might be able to reach it, these things are in the way :-(
Need to get it up on ramps.
We don't even have a bit of kerb here that we could bump it up on to raise one side.
Old Aug 12, 2012 | 05:17 PM
  #274
landsharklady
Hey, anyone watch the olympic closing ceremony?
Does it make any sense to you people across the pond?
Old Sep 21, 2012 | 02:13 PM
  #275
landsharklady
Call from mechanic today, car has been in for cam belts flex plate etc.
Remember, when w bough the car, Brooklands Garage, Kent, assured us they'd checked it over and that the flex plate tension and cam belts were all fine.
Nope. The belt was ok, but the tensioner and rollers were very much NOT OK AT ALL!
And the flex plate thingy moved 4mm.
And we need a new radiator- mysterious leak came from radiator :-(
And it pulled the no-start trick, guess new ignition switch didn't fix it. They bridged the starter relay which didn't work, so they believe it's a wiring fault on the fuse board as it started after the board was jiggled slightly.
And the ABS sensors are all fine- so presumably fault is on a wire somewhere.
I'm going to cry now.
But soooooo relieved we got the belts and tension checked!
Old Sep 21, 2012 | 02:17 PM
  #276
alabbasi's Avatar
alabbasi
It's still a pretty car though! I wonder if 928 radiators can be re-cored?
Old Sep 21, 2012 | 02:20 PM
  #277
landsharklady
They reckon it can, looking at about £250 for that, of a smidge under £300 for one from a porsche breakers- car it's from is an insurance write off, but it had a new radiator less than a year before it got written off, so pretty good. Just waiting for a few more quotes.
Old Sep 21, 2012 | 02:24 PM
  #278
alabbasi's Avatar
alabbasi
A re-core is probably better then a used one. It's funny how every part from a breakers yard is from a low mileage car, driven by a nun, yada yada yada .
Old Sep 21, 2012 | 02:28 PM
  #279
Maybach_Man's Avatar
Maybach_Man
why dont you bring it to Tilford in October, you can get all the advise you want!
Old Sep 21, 2012 | 02:29 PM
  #280
Maybach_Man
oh.BTW go for a new core!
Old Sep 21, 2012 | 02:31 PM
  #281
landsharklady
What's happening in Tilford? and when is it? we're touring through october, so if it's a weekend, no way :-( Sad times.
And thanks for the advise, I'll go for recore.
Oh, the breakers did actually have a cheaper one which was older!
Old Sep 21, 2012 | 02:32 PM
  #282
landsharklady
Where "Near London" are you Maybach? We're also "Near London".
Old Sep 21, 2012 | 03:17 PM
  #283
Pagnobito's Avatar
Pagnobito
£250 seems about right for a re-core, I had my 1979 re-cored in copper (manual car) for £240 from a guy in a shed near Gravesend.
Tilford is 6th October but as you are touring I doubt you will make it, good luck with the tour!
Old Sep 21, 2012 | 03:38 PM
  #284
Maybach_Man
Hi Tilford is the big 928 UK meet in the south its on Saturday 6 th oct. Weekend gigs are a real pain... been there done that im in Stoke Poges which is near Beconsfield
Old Sep 21, 2012 | 03:43 PM
  #285
landsharklady
Aha! another person in a band with a 928- cool!
6th oct we're playing Bradford, ***** :-(
I've text my mechanic, we're going with a recore. We're based near Gatwick (not crawley)
