Front fuel hose warning / reminder
This was already covered in some post, but somehow it didn't catch my attention well enough. On my S4 (and I imagine GT, GTS, maybe 86.5) the front fuel line bteween the two fuel rails rubs against the oil filler neck. If it rubs long enough the hose will burst.
I replaced mine about three years ago, presumably the new versions are longer to prevent rubbing, but I discovered today the hose was nicked. Ever so slightly, but a start nonetheless. A $30 part versus your prized possession on fire. I'm not taking chances.
I vaguely remember seeing some pics with protecting sleeving applied but can't find them. Here's an old post with another remedy: https://rennlist.com/forums/928-foru...uel-lines.html
Don't be a sucker. Check and replace yours!
Former Sponsor
Roger at 928 R Us stocks these, with my "new style" crimp ends and Teflon hose. Guaranteed, for the life of the vehicle!
If you route the hose properly, it will not rub. Requires a slight amount of twist with tightening the uniion nuts with a flare wrench.
![](http://i50.tinypic.com/35aukqd.jpg)
The factory fuel jumper hose is protected with an outer protective cover, so what your seeing is, just the cover, not the pressure hose which is much smaller.
I don't think Porsche ever made that hose longer. I make all my replacement hoses long enough for the installer to "shape" them so that they will not touch the filler neck.
That's the one. Some hose manufacturers also supply hose protection stuff like that.
Former Sponsor
You suppose the stock hose "shrinks", over time?
Initially I placed my line in the manner where there was no contact. Over time there was contact. I then placed three large black wire ties strategically under where the filler neck contact point would be. The hard smooth surface has acted well against the filler edge for two years now.
Rest in Peace
I took care of that problem and put your hoses on mine, so I am on my second set of replacement fuel hoses.
Greg, Aryan,
What's below the protective rubber cover is actually plastic (polyamide) tubing. So its not a hose per say.
On the hose shrinkage topic..... that sounds like a possibility. When you strip back the protective cover the polyamide tubing appears to be heat shrinked at the factory. However, according to Porsche, the polyamide tubing is said to be pressed on instead. The Polyamide tubing is pretty tough stuff, but likely shrinks with age and temperature.
I'm just not sure how much that shrinkage might be. More likely to me is, the hose was just in most cases improperly installed at the factory with an interference fit.
The factory installed hose on my '90 S4 only had a small dent in the protective cover.
![](http://i48.tinypic.com/23i7bkk.jpg)
