rear hatch gap adjustment !! how?
iv'e tried a few searches and haven't found how to adjust the closed rear hatch door gap with the rear bumper.my hatch operates perfectly but looks as though is sitting slightly up from the rear bumper,the gap is a couple of mm too much.its barely noticeable but would like to set it exactly. i think it was ok before its respray last year. its 81 euro if that makes any difference.
Under the Lift
The rubber bumpers in the corners can be screwed in and out. That's the common adjustment point. If that doesn't help, then you need to go further into this, as Randy indicated.
i too have a noticeable gap, i have new insert, the bumper on both side are adjusted to the lowest, the motor is adjusted to so it just releases, my wiper works perfectly....rubber bumper in the corners? There's more adjustable bumpers? sorry for the ignorance.
