Why is there a 5-way splitter and a 7-way splitter
when on the 7-way splitter two vacuum ports are plugged?
Inquiring minds want to know
Former Sponsor
Because the people that make the splitters had an entire box of "over-run" 7 way pieces and they sold them to Porsche cheaper than the 5 way?
Actually, I think that you probably have a 5 speed. On an automatic, one of the two extra ports goes to the modulator, leaving only one port?
Can't figure it out. Maybe the 7-way is a relic of an older MY design?
I have an automatic, but with a 5-way splitter. One to the intake, two to the FPR, one to the FPD, one to the trans modulator.
On a 5-speed, are only four ports in use?
Archive Gatekeeper
Yes- 1 port from the lower plenum, 3 out to the fuel dampers and FPR, and 1 blocked.
WSM diagram, with the 5th port going to auto transmission:
Right, thanks for confirming. That picture is the promised land I will never reach but I can at least clean the engine up.
How are ports plugged from the factory? I've seen the put-in-a-screw method, but it is a bit too much shade tree mechanic for me.
Archive Gatekeeper
IIRC there are little black plastic mushroom-shaped plugs. I have an extra old 5-way somewhere in the garage, will try to take a pic tonight.
Former Sponsor
They make a small metal plug to fit into the rubber tee. They are available.
Archive Gatekeeper
Ah! 'Stopper', 900 312 012 02.
Archive Gatekeeper
Pelican says NLA but 928Intl lists them. Maybe they'll have 'em- certainly used, at least.
