GTS Cam Broke What Would You Do?
#91
Former Sponsor
Even some of the engine analyzer programs show valve float occurring in a GT with stock components, and that's with the valve springs being in new condition. Valve springs don't last forever.
It's not too hard to find people here who have replaced their suspension springs because the original ones were worn, weak, soft, or sagging. You'll also see where people have replaced or repaired the foam or springs in their seats for the same reasons. How many times have you heard of someone replacing their valve springs for those reasons, even though the valve springs have led a far harder life? Every time the valve springs go through a cycle they're flexed to pretty much their full range, and it's happening whenever the engine's turning. Up near redline, it's occurring over 50 times per second.
It's probably kind of hard to convince most people that they should spend $1k+ for new springs that will look identical to the ones that they'd then take out and throw away though. Even when they do a valve job, the same old valve springs seem to usually get put right back in, without even checking to see how soft they've become.
Compared to the same valve spring in an S4 or GTS, the one in a GT has to flex further with each cycle, faster at the same engine RPM because it has to go further with the higher lobe lift, go to a higher engine RPM with the higher GT rev limiter, and get flexed like that more often at the same road speed, because of the lower differential gearing. The 32v '85-'86 engines have the same cam lift as the GT, but they don't have as high of a rev limit, have higher differential gearing, most of them have an automatic transmission, and have they smaller, lighter valves. Porsche used stiffer valve springs in the later 944/968 engines, and it's probably pretty safe to say they did it for a reason.
Boost can make the problem worse because it adds additional force to the back of the intake valve, which acts against the pressure of the spring, effectively making it weaker to some degree. If you think about the actions of the valves and piston in a cylinder, and what they're doing as the engine goes through it's cycle, the bigger problem may actually be more likely to occur with the exhaust valves from high exhaust backpressure. That's usually even more the case with a turbo, because of the higher exhaust backpressure in them. Porsche put stiffer valve springs in the 951 too.
Of course even normally aspirated cars can and do have exhaust backpressure. More horsepower made often means more airflow through the engine, and therefore more exhaust to get rid of. A GT makes more power than an S4, but has the same exhaust manifolds, so higher exhaust backpressure at the exhaust valve in a GT would be expected when compared to an S4 making lower power. In his thread, Heinrich mentioned the pitting being on the exhaust cam lobes of his GT engine. Just a coincidence?
The oil used and it's temperature have nothing to do with the type of GT cam pitting that's being discussed. Oil related issues would be worst where friction and load are highest. That would be where the lifter is climbing up the cam lobe, with the spring being compressed, and the valve train components being moved to the valve open position at the fastest rate. The pitting seen is after the peak of the cam lobes though. That's the area of least load and friction, and where you'd expect to see the least wear if there's an oil related problem.
Imaging a car speeding up a hill. The driver is pushed down into the seat as he zips up the hill, the suspension is compressed, and the tiires are pressed hard against the road. The car gets to the crest of the hill, the driver feels weightless, and the car goes airborne. It floats along for a moment, then comes crashing back down against the road, like it does in every episode of the Dukes of Hazard. That's exactly what the lifters are doing as they go over the cam lobes in a GT up near redline. They get slammed down against the cam lobe by the valve spring, when it finally overcomes the inertia of the valve train components from when they got flung open. The material of the cams is at least somewhat brittle, and it's just a matter of time, with enough of that hammering, that the lobe starts to chip, and you have the pitting develop.
They aren't specifically 928 engines, but here are a couple of web pages found with a quick search that are talking about basically the same isssue:
http://www.thumpertalk.com/topic/887...t-watcha-think
http://www.circletrack.com/techartic...t/viewall.html
http://www.lindseyracing.com/LR/Part...VESPRINGS.html
I'd still "play it safe" and suggest to people that it is probably not a good idea to run around with 280 degree oil, regardless if the cam pitting is caused by hot/thin oil or by valve float...
#92
Former Sponsor
when I worked for Valvoline in the lab, we were told that for every ten degrees past 212 the life of the oil was cut in half.
I start really worrying about the oil at 230, anything over that, it is too hot IMHO.
I do not have a oil temp gauge on my 928, but as soon as the carputer is ready for sale and I get one I will have one.
Regarding temperatures:
Grab a customers' car with just the lower oil cooler.
Install undertray.
Idle in traffic on 100 degree summer day for 20 minutes with the A/C on.
When the oil pressure idiot light starts flashing....check the oil temperature.
#93
Under the Lift
Good question, any opinions? These cams are getting retired, but here a question: If you pulled off the cam-covers for paint, and found a few lobes that looked like that, would you (a) put the covers back on real fast and forget the paint, or (b) peel off a few more Porsche-bucks for new cams(and lifters and springs), or (c) shrug, paint the covers, and be happy?
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Bill, nothing in the filter either. I don't peel it open every change, maybe two out of three, but I've never found anything except a few flecks of carbon (not magnetic).
#94
Former Sponsor
Is the nose damage Jim shows "acceptable"? I have NO expertise in this, but I thought pitting on the nose is like potholes - it's a sign of material (metal) fatigue, not friction wear, and it just gets worse. The fragments/flakes are relatively large and don't show up in oil analysis but end up in the filter. Maybe a few get caught by the drain magnet. So, it could be current despite decent lubrication and negative oil analysis.
That damage is so far down into the surfaces that re-grinding would be futile.
#95
First question, are the valve springs on the GT and the GTS the same? Does PET give the same numbers?
Second, are new lifters from Porsche original stock, or those currently made by INA?
Lifters ordered from Porsche for the 944 Turbo come from INA and do not match the hardness of original lifters.
Another point on lifter failure on rebuilt heads. My local mechanic says the lifter failure he has seen was from the wrench removing and installing lifters scratching the bore. If the bore is scratched any at all the lifter does not spin and that causes the damage and failure. Using the coated lifters would help tremendously with this.
#96
So did my valve spring question stump the experts? Or is it because if they are different part numbers, I would ask what the difference in the rates are?
#97
They said its the same for all 87+ cars, don't know part # is different. Somewhere in this thread or the last one Greg mentions something about them being the same.
http://www.mailordercentral.com/928i...105%20905%2007
#98
So these cams are scrap and have no core value? What do a new set of GT cams run for these days or is custom the way to go now?
#99
I think the consensus is the gt cams are unobtainium as new. Mike Simard will develop whatever you need at a very reasonable price---custom for what ever need you have....
#100
Stumbled across this info "Comp Cams Recommends Using High Zinc Content Oils for Break-In
A technical bulletin from Comp Cams and the recommendation from Crower to use high zinc content oils for break-in of flat-tappet cams comes in response to the growing problem of cam failure during initial break-in. Joe Gibbs Driven BR is the only fully formulated oil designed specifically for breaking in flat-tappet cams. The high zinc content formula has been used to break-in every flat-tappet Sprint Cup engine built here at Joe Gibbs Racing for the last 6 years. In fact, the development of BR reduced the number of camshaft failures during break-in at JGR from 1 in 10 to 1 in 40.
Proper preparation of lifters and cam lobes by polishing both the lobe and lifter foot aid the break-in process and futher reduce break-in failures. It is also critically important to ensure proper parallelism of the cam lobe and lifter. For improved break-in success, we recommend that you use our Engine Assembly Grease to coat cam lobes, lifters and pushrod tips during assembly. Then use BR petroleum based break-in oil during break-in. We also recommend that you use a tape of chemical polisher to improve the RA finish of your cams and lifters prior to break-in. Some companies sell pre-polished products, so you don't have to buy the equipment to do it in house. Again, there is no substitute for proper lifter to lobe geometery, so once you put the right pieces in the right places, you now have the right oil and assembly grease to protect you investment in time and hardware."
Speaks to the importance of the zinc , and polishing the parts to a fine finish.
#101
Rest in Peace
Most of that is written for cam in block motors, while it still applies to all cams, we do not depend on windage for cam lobe lubrication like most of the cams that Comp sells.
Any thing you can do to improve your chances will help.
#102
Former Sponsor
Same spring, with more aggressive cam design....thus the problem.
A new "stock" spring with .425" of lift and .060" of coil clearance will provide 173 pounds open and 64 pounds on the seat....not hardly enough.
The "commonly" used 944 spring, with .425" of lift and .060" of coil clearance will provide 208 pounds open and 83 pounds on the seat....way better, but getting a bit "high" on the open pressure and still a bit "weak" on the seat.....especially with stock lifter weight and 968 intake valves. This is about the "maximum" lift that this spring will tolerate and still be able to get the spring into the head, with a spring seat. Note that this spring can be "shimmed' tighter on lower lift cams, which will increase both the open and installed pressures....if this is desired. Note that the higher the open pressure gets, the higher the friction is, when the camshaft turns. On a 4 cylinder engine, increasing the spring pressure 20 pounds will decrease the output of the engine about 8 horsepower. Ask me why I know this, some other time....
The Porsche "race" spring that I use, when lifts get at this point, have 197 pounds open and 94 pounds on the seat....virtually perfect. (again, at .425" of lift and .060" of coil clearance.) This spring will work great with lifts up to about .450".
Too much information?
#103
Wow,
I think I have seen more posts that give more and more insight into how and why Greg does things over the last couple of months.....thanks for all the info ...it is all really insightful.!!!!!
I wish Greg would write a book!!!! I would buy it just for the info though I will never build an engine..
andy
andy
#104
