85 oil pan on GT no worky
928 Collector
I was going to use a spare 85 pan I have (early model) for a few reasons on my 91GT motor. But 2 things don't work.
1) pickup expects a deeper pan. Which must mean a GT pan is deeper (will have to compare as I've already packed the GT pan away in storage)
2) GT pickup sits off-center which doesn't allow the pan to center.
Has anyone seen this?
Team Owner
can you post pictures of both pans?
the pickup should be centered any chance it has gotten knocked around
Archive Gatekeeper
That's very strange- The oil pan on my '91 GT donor motor for the stroker was cast in '83 and had the oil drain pipe return hole in in (blocked off). Seemed to fit just fine. It was the one that was quite difficult to remove 'cause of the goo gluing it on.
Team Owner
any chance that you damaged the pickup while hitting the oil pan to remove it
928 Collector
85 pan measures exactly the same depth except that the anti-slosh vanes are slightly offset and slightly longer. So the GT pickup won't work with an 85 pan (too big and offset) unless modified but since I plan on using an ob pickup this may be no issue.
That looks very bent.
928 Collector
Not bent. (edit) The GT pickup is just about 11mm bigger. I think that's part of the problem. The GT pan accommodates for this, the 85 pan not. I thought the 2 pickups were angled differently but closer inspection reveals I was wrong.
