928 Forum 1978-1995
Sponsored by: 928 Specialists
Just Peachy OB project
Old 09-10-2018, 06:06 PM
  #886
SpearLazyT
SpearLazyT's Avatar
Reminds me of the story of the old sailboat guy, just before bed he is saying his prayers and says, "Lord forgive me, I rode in a powerboat today, and liked it." Will that be Stan; "Lord forgive me, I worked on a LS engine today and liked it"?
Why did you need a new engine harness?
Old 09-10-2018, 06:36 PM
  #887
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,518 Likes on 1,419 Posts
I know how to change the coolant and oil on a LS 3 engine
the harnes was swapped because it got water damage and was also showing internal shorting and at this point it was easier to swap in a new part than try to repair the old harness
That said I did get my eyes on a new Corvette TT and auto transaxle that will fit into a 928 just gotta figure the engine part
Old 09-10-2018, 09:40 PM
  #888
77tony
77tony's Avatar
Most of the GM engine harness damage was caused from a loose negative battery strap...moisture took over from there. Tom JP unfortunately will not make it to Frenzy this year. T
Old 09-10-2018, 11:41 PM
  #889
andy-gts
andy-gts's Avatar
Hmmmm , I missed something way back, I thought just peachy was up and running a couple yrs ago.....what is changing, was there a short or is this just for a new stereo ?????
Old 09-11-2018, 04:27 AM
  #890
77tony
77tony's Avatar
Originally Posted by Adk46
I've been studying electric conversions lately, which can provide greater power and heresy than a Chevy motor. Call it "Just Peach-E".
For sure Curt. LS lump is in and its staying. Have been looking at Tesla Model 3's for Tambra though. T
Originally Posted by andy-gts
Hmmmm , I missed something way back,I do the I thought just peachy was up and running a couple yrs ago.....what is changing, was there a short or is this just for a new stereo ?????
Hi Andy, You may have missed the Infinity Box wiring system that was chosen some time ago...more on posts 806-807, 852, 862, and 872^^ T
kiwiokie (05-09-2020)
Old 09-11-2018, 09:06 PM
  #891
FLYVMO
FLYVMO's Avatar
Tony is way too diplomatic and nice. While Stan and I were working on JP, we had to correct many items such as fried fuse sockets, shorted/corroded connector pins (water damage) improperly installed shock springs, missing shock dust covers, missing shock bumper stops, cut up pieces of shock dust boots used as spacers, home-made crimps and bypassed wires in the GM fuse box, just to name a few....some pictures of the before horrors.
Thanks to the help of Stan, JP will be very well sorted out mechanically, and when the interior wiring is finished it will, once again, be an awesome car. Tony spares no cost when it comes to making things right.
We also encountered an issue with factory new shock dust covers not fitting properly onto Koni shocks. We acquired a special tool (Stan knows the name of it) and the dust covers are easily modified to fit properly. Again, I learned a bunch more from Stan's excellent wrenching skills.
New dust boot
Water damaged connector
Fried fuse
Leftover pieces of old dust boots someone used for spacers on the shocks
Mmmm, nah
Duh
Really?
Old 09-12-2018, 10:37 AM
  #892
FLYVMO
FLYVMO's Avatar
Here are some pictures of the correct spring alignment and the tool used to correct the shock dust boot inner diameter to fit onto the Koni shocks.
Dust boot for shock
5/8" tool
Correct spring-to-perch alignment
Old 09-12-2018, 09:30 PM
  #893
Mrmerlin
Team Owner
Mrmerlin's Avatar
Thanks for the pictures Carl.
This is a rewiring job that really has to be seen to fully grasp the depth of commitment thats needed to see through.
Carl is a wiring wizard, and perfection is how he rolls,
thanks for letting me watch, I have been learning.
That tool we got at HD and it made the plastic hole just right to fit over the slightly thicker Koni shock piston
Old 09-12-2018, 11:23 PM
  #894
andy-gts
andy-gts's Avatar
very impressive you guys are so valuable.......!!!!!!!
Old 10-30-2018, 12:11 AM
  #895
77tony
77tony's Avatar
you’ve got that right Andy^^we will we be seeing you at 3rd Coast this weekend?
A proper fuse holder for the fan controller, waterproof and 10 AWG.
Old 11-01-2018, 09:26 AM
  #896
928 GT R
928 GT R's Avatar
Received 5,476 Likes on 2,103 Posts
Tony,
I have read about 1/3 of this thread and am simply amazed by your "Just Peachy" project. Can't wait to see it in person!
And as an aside, the Merc is a much better value for money car than the Tesla for Tambra... But you know that...
Enjoy!
Old 11-29-2018, 03:57 AM
  #897
chart928s4
chart928s4's Avatar
Tony - saw you posted info in the "weight" thread but what's the latest on JP? Assume it's up and running? Any pics?
Old 11-29-2018, 01:42 PM
  #898
77tony
77tony's Avatar
Carl (FLYVMO) is out of country and informed me that wiring will be completed when he gets back home. Thats all I got and thanks for checking in T
Old 02-06-2019, 12:44 AM
  #899
77tony
77tony's Avatar
Default Cluster, etc...
Recently purchased a late model digi-dash for this OB from Mark A, (will be loading it up with LED's), four new connectors w/pins, an early 89 non-airbag combo switch from a fellow RL'r, and wired the HVAC head to work with the Infinity Box system. Carl (FLYVMO) doing a bang up job putting it all together T
Old 02-06-2019, 08:46 PM
  #900
77tony
77tony's Avatar
A rare bird..an early MY89 combo switch sans airbag to control the digi-dash. The four connectors/pins now installed took Carl 5 hours...and a few sore fingers T
Quick Reply: Just Peachy OB project
