928 Forum 1978-1995
Sponsored by: 928 Specialists
Just Peachy OB project
Old 07-03-2014, 08:30 PM
  #631
The Fixer
The Fixer's Avatar
You're a good photographer T, they look great together..
Have a great 4th!
Old 07-04-2014, 12:14 AM
  #632
77tony
77tony's Avatar
Have a great 4th!
Thanks Matt, Not to bad for a cell pic. T
Old 07-04-2014, 12:31 AM
  #633
Dinsdale Piranha
Dinsdale Piranha's Avatar
Cool color!
Old 07-04-2014, 01:06 AM
  #634
Bigfoot928
Bigfoot928's Avatar
tony needs to get a pic of the 928sg with the dinsdale treatment and 600hp at the ground..... 600 high hp revving 335 30 15 road grabbing tires hooking up and completing a sub 4 second 0-60 mph experience....
Old 07-13-2014, 10:58 PM
  #635
77tony
77tony's Avatar
Moved the JVC head unit from the pass side shelf (now deleted) into the center console. Plan is to reroute the iPod into the raised center armrest for easy access. T
Old 07-14-2014, 08:43 AM
  #636
Chuck Schreiber
Chuck Schreiber's Avatar
Looking good there T!
Old 07-15-2014, 12:45 AM
  #637
77tony
77tony's Avatar
Thanks Chuck. Fits nice. T
Old 07-15-2014, 09:34 AM
  #638
FLYVMO
FLYVMO's Avatar
Your filing skills are exemplary Tony! Looks great! Told you it would fit
Cheers!
Carl
Old 07-15-2014, 09:58 AM
  #639
RKD in OKC
RKD in OKC's Avatar
Hey T, did you figure out a place to put a front center speaker?
I have that JVC head in my Range Rover and with a front center speaker it does 5.1 surround. The Rover had an old unused center speaker spot on the dash and LOTs of room for a 4 channel amp, 2 channel amp and a sub woofer in the back.
I have a Land Rover logo on the screen, want me to make you a Porsche or 928 LS logo for yours?
Old 07-15-2014, 12:10 PM
  #640
77tony
77tony's Avatar
Originally Posted by RKD in OKC
Hey T, did you figure out a place to put a front center speaker? Do not see a place for it
Sure. Had this logo saved but would like to see what you have. T
Old 07-15-2014, 12:39 PM
  #641
RKD in OKC
RKD in OKC's Avatar
This is the rover logo I did, took a while to figure out the correct size so it would display properly, And had to dim it down a little so the white buttons would show up. It actually looks pretty bright on the radio screen.
Will throw a couple or three screens together for you and post them...
Old 07-17-2014, 10:20 PM
  #642
77tony
77tony's Avatar
A/C compressor has not been kicking on. Freon levels checked are fine, so jumped the HVAC compressor relay (in the ce panel on these older cars and not in the control head), freeze switch and low pressure switch. Nothing. Pulled the HVAC head and found the culprit. There is no A/C button to push on these older heads and they are activated by moving the bottom slider to "AC". The A/C slider has an internal bump that pushes a small button on the front of this switch, which in turn activates the compressor. There was a small stress crack running underneath the red switch and to the edge of the housing. This weakness in the housing was preventing the button on the front of the switch to depress fully. JB welded the base around the switch and reinforced with a small piece of ABS plastic. Will reinstall the head unit on Sat. T
Last edited by 77tony; 07-18-2014 at 02:33 AM. Reason: Increase lighting on HVAC Head unit
Old 07-17-2014, 10:49 PM
  #643
The Fixer
The Fixer's Avatar
Nice work T man!
Guess you didn't need a professional to take care of this after all.
I'm impressed.
I've always thought becoming a decent auto mechanic begins with taking the time to really just LOOK.
Old 07-18-2014, 09:48 AM
  #644
Chuck Schreiber
T,
Good time to put your LED's in the head unit while you have it out.
Old 07-18-2014, 04:01 PM
  #645
77tony
77tony's Avatar
Nice work T man!
I'm impressed.
T,
Thanks guys. Just found the Jager LED gauge illumination kit, HVAC upgrade, circular clock upgrade and dimmer control. Hope to get the center console back together this weekend. T
Quick Reply: Just Peachy OB project
