Just Peachy OB project
#393
Tony, have you seen the Borla induction systems available for your LS motor?
Really beautiful. http://borlainduction.com/v8_kits/v8...76_pic1_lg.jpg
#394
Looks awesome Tony!
Is there any way to get the air filter out of the engine bay? In TX summer heat that motor will be pulling in some really hot air with the filter in that location.
#395
Fixer, You said on post 392 and I quote "that's a perfect fit, Look incredible" Now you want me to spend big $$ installing a Borla induction system
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Thanks Cramer. Thinking of designing & building a belly pan to vent cooler air from below. T
#397
Runner would look damn good in that gold![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
I have a dual split filter that I will add later in front the radiator when the supercharger gets mounted. I don't see it blocking much air.
Can you post how you did your battery cable, alt. cable, and/or starter main cable?
#399
Dinsdale did a beautiful job with all the wiring. Will take pics of the batt, etc cables next time I'm at the shop. If you need pics now for your build, contact Dinsdale and have him take a few pics for ya. T
#400
My main wiring is done, waiting on custom harness to show. I found the factory battery cable connects perfectly to the lower driver's side mounting location of the GM alternator. I just piggy-backed off the alternator to the starter main and 3-point loom main with large 4-gauge wires.
#401
Fixer, You said on post 392 and I quote "that's a perfect fit, Look incredible" Now you want me to spend big $$ installing a Borla induction systemThey do look great on older Hot Rods sans hoods, but think we will be staying with the tried & true stock GM injection system.
No, I don't want you to spend more $. Just wanted people to see the kind of stuff available, I thought you'd react that way..
They are supposed to fit as low as stock intakes however.
I wish this kind of stuff was available for the 928, that's the beauty of the chevy/ford motors there's so much available.
J.P. Looks great.
J.P. Looks great.
#402
J.P. Looks great.
J.P. Looks great.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
