Trouble removing main pulley bolt (solved)
Under the Lift
You'd be surprised how little 218 ft-lbs is. Should be easy, BUT whatever gorilla did Nicole's timing belt before we did a couple of years ago must have put about 600 ft-lb on it. Yes, 3/4" drive or bigger and 4+ foot pipe is needed if this bolt has been overtorqued. Harbor Freight sells an affordable 3/4" drive ratchet/socket set. Add 4' of 1" ID pipe and you should ready for this and the rear axle bolt. The S4 fan shroud is in the way for getting to the crank bolt, but the HF ratchet and short extension will fit after that is removed. Make sure the flywheel lock is very well seated so it doesn't slip and wreck any teeth. It held on Nicole's car.
[BROKEN RECORD]With the right tool this is so easy it's embarrassing. Go to your local tractor or big truck maintenance place and offer a big deposit to borrow a torque multiplier, at least 4:1. It will make the job no more difficult than removing a wheel nut. I don't know why more don't own this thing (other than its price of course. And I'm speaking of US made- HF and others have cheapies I would not necessarily trust, although YMMV). Blade bolts on my rotary cutter are tightened at >700 foot-pounds, translated to a manageable 175+ with said tool. [\BROKEN RECORD]
We have princess auto here in canada. They gave two torque multipliers.
http://princessauto.mobi/index.php?option=items&task=search&q=Torque+multiplier&btn=Search
I just took mine off Tuesday to do a WP/TB. The guy before me used a BF pipewrench to get it off last time. I have a pipe wrench that size that my grandfather used to work on mining equipment back in the the 30's.
Captain Obvious
Super User
Super User
http://princessauto.mobi/index.php?o...ier&btn=Search
The starter method didn't work for me, it was on tighter than the torque of the starter.
what a hell of a job, this is how i did mine. drilling a hole in the middle. It was a bit risky, but i had no other option. after that it came off whit a normal socket driver
Under the Lift
Patrick: Wow! Nicole's had me worried at first, but it came free at about 600 ft lbs. Some have jacked the car up enough to use the weight of the car on a monster breaker to get it free.
Everyone should have one of these. 1"'er.
I stole it from Roger so no idea where he got it.
I gues it was the tension that came of bolt so yes weakened I din't use heat, just drilling. First a small drill the second a larger dril. an do it straight.
A lot of good suggestions, so I will add my 2 cents worth.
Best quality 27mm socket, 3/4 "T" handle and 6 to 7 foot length of pipe and a good fitting flywheel lock. Insure socket is fitting square, take up tension and apply torque by brace pulling clockwise. if does not move use a longer piece of pipe and apply steady increasing torque mindful of your own safety and if it lets go it does not hit the fender or your head. (Not good to hit your head with a steel bar/pipe. Don't ask me how I know, part of the learing process with working on large marine diesel engines and not so good experience in Teintsin Hospital in 1965).
To ensure that hex ends on bolt head are not rounded from socket slipping off during previous attempts. If hex head is damaged use a full hex socket.
Tails 1990 928S4 Auto
Chronic Tool Dropper
The deep impact socket from H-F is a 6-pt, fits nicely on the bolt. Leaving out the short extension needed with a regular socket means less slop and less torque windup vs the deep socket.
I have a legacy piece, a 3/4" drive piece that originally had a sliding crossbar/T through it. It's a perfect place to stick a 4+ ft long tapered demolition bar. No pipes, no other extensions, just the bar. Rob has used it at my house too, and it's relatively effortless. Get the right tools, big enough for the job. There are just a few places on the car where the big tools are needed, and there really is no substitute.
For those in the Los Angeles area, this stuff sits idle for months or more at a stretch; feel free to come by and borrow them for your 928 project. Perhaps someone near the OP can share the right tools and a few minutes of help to get him on his way?
