928 Forum 1978-1995
Sponsored by: 928 Specialists
Old Sep 3, 2011 | 05:37 PM
  #31
928er's Avatar
928er
Indeed this has been a long road. However it is a journey that I took voluntarily & I knew it wasn't going to be easy. yes there are parts of the variocam development that I refuse to share. These were hard fought lessons, and expensive to boot. I don't want to fault anyone when they don't give away what they have learned for free. Especially if they make a living using the lessons learned. In the course of my project I did have people that willingly shared information with, me and if it was in confidence I will not share that publically either.
Old Sep 3, 2011 | 05:40 PM
  #32
SeanR's Avatar
SeanR
He's not ****ting you either, I've been trying for a few years to get some info out of him and he's shut as tight as a ..........nevermind.
Old Sep 3, 2011 | 06:40 PM
  #33
GregBBRD's Avatar
GregBBRD
Former Vendor
I can relate to this.
I share many things....but there are at least as many things which I do not share as there are things I do share.
There aren't many pictures of the inside of one of my engines...and the pictures that do exist are "hand selected" by me.
I think Rob Edwards might have said this best, when talking about my oil removal system, for the heads: "Hell, even if someone had detailed pictures of the outside plumbing and drawing of the details, they would never be able to duplicate what is happening inside of the engine....so does it really matter?"
He had a good point, and I allowed him to post a couple of pictures.
I like that Sterling is doing this...and accepts that there are going to be "bumps" in the road.
Small failures are always present in any developmental road....
Old Sep 3, 2011 | 07:03 PM
  #34
heinrich's Avatar
heinrich
928 Collector
Truly not my business Guys ... and Sterling is a friend. The difference in my humble opinion, is that Greg you run a business. Just my 2c, I really believe Sterling, that with open information sharing, there would in fact be a small but successful cult following of 928's driving around the world with Variocam.
Old Sep 3, 2011 | 07:56 PM
  #35
928er's Avatar
928er
I've said it before and I'll say it again... variocam on a 928 is not cost effective. you could purchase multiple boost kits, (choose the most expensive one you can find and buy 2) and still not spend what the variocam costs... you can get multiple times the gains of variocam, for 1/4th cost......
Old Sep 3, 2011 | 07:57 PM
  #36
SeanR's Avatar
SeanR
Sooo, when are we testing what you have left over on my 5.0?
Old Sep 3, 2011 | 08:33 PM
  #37
Glenn M's Avatar
Glenn M
Sterling,
Sorry to hear about your engine, hope it isn't too bad.
Good luck!
Old Sep 8, 2011 | 02:00 AM
  #38
928er's Avatar
928er
got the timing belt cover off. little bits of teeth everywhere. have not been able to get the balancer off to see the carnage.... engine is indeed coming out.... this weekend for sure if not by then.
Old Sep 8, 2011 | 02:06 AM
  #39
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Sorry to hear it, Sterling- Better, stronger, faster, next time!
Old Sep 8, 2011 | 02:19 AM
  #40
928er's Avatar
928er
I may have some goodies for sale......the last harmonic balancer that was in porsche stock a few years ago.... a RR fuel pressure regulator, big bore throttle body...and a few other bits.....968 variocam parts
Old Sep 8, 2011 | 02:34 AM
  #41
928mac's Avatar
928mac
Looks like it is time to go with stage 2 in your signature
Sorry it had to be this way Sterling.
here is an interesting read on the toyota VVT-i issue
http://www.tundraheadquarters.com/bl...ndra-gear-tsb/
Good luck and wishing you min cost
Old Sep 8, 2011 | 06:47 AM
  #42
S4ordie's Avatar
S4ordie
Not the sharpest tool in the shed
So sorry to hear about this Sterling. Frustration is probably the nicest word to use at this time. Thanks for pressing the outer limits as a 928 Privateer.
Old Sep 8, 2011 | 07:57 AM
  #43
Mike Frye's Avatar
Mike Frye
Craic Head
Sterling, you are a god.
I have no idea how many hours of planning, work, waiting, planning, more work, more waiting you have in this car. The cost of those is a labor of love I know but still a cost. Not to mention the cost in actual dollars.
I've been following your progress on this car since I got here 5 years ago and I'm always amazed at your level of ambition and talent (two things I admire but that are rare in the same individual).
Good luck with the rebuild and whatever direction it takes you in. Take a deep breath, stand back, and then keep pushing forward.
Old Sep 8, 2011 | 09:48 AM
  #44
Mrmerlin's Avatar
Mrmerlin
Team Owner
Sterling I just got back to this thread to answer your question.
regarding pulling the dipstick out and taking a small sample to check for metal in the oil.
It is actually a very quick way to spot internal damage possibly before it gets to be catastrophic.
The only thing to consider is how the oil sample is taken,
as putting the dipstick will usually remove small pieces of dipstick tube and possibly taint the sample,
hence the suggestion to use some lamp cord put down the tube .
Sorry to hear about the broken belt ,
if that has happened then turning the cams may offer some info on the failure.
It is quite possible for the ball seat on the anti back flow valves in the heads to be loose,
if so then the seat can get pushed upwards and then cut off the oil supply to the head once this happens you have about 2 mins of running before the cams seize
Old Sep 8, 2011 | 04:23 PM
  #45
Gary Knox's Avatar
Gary Knox
Sterling,
As others have said - so sorry to hear this happening. You have a beautiful car, and have put a lot of time, energy, and $ into it. Hope this time it "all comes together", whateever direction you proceed with the rebuild of your engine.
Gary Knox
