928 Forum 1978-1995
Sponsored by: 928 Specialists
PWM dimmer for instrument backlighting after upgrading to LEDs
Old 04-02-2020, 05:15 PM
  #271
aseem
aseem's Avatar
This has been on my to-do list for many years. I remember reading through this thread and your very good instructions, but never got around to ordering.
How much is it again?
Thx
Arnljot
Old 04-07-2020, 04:18 PM
  #272
Paul Lakner
6th Gear
Paul Lakner's Avatar
Hi, Id be interested as well for an 85’ when they’re available. Thanks
Old 04-08-2020, 08:41 AM
  #273
Drewshepard60
Drewshepard60's Avatar
I would be interested also
Old 04-08-2020, 08:42 AM
  #274
Drewshepard60
Old 04-15-2020, 08:05 PM
  #275
Ed Scherer
Ed Scherer's Avatar
Wink
All you guys posting over the last few weeks, check your PMs for some good news.
Old 08-29-2020, 08:45 AM
  #276
ktonini
ktonini's Avatar
Hey Ed, did you guys figure out if these would work for a 968?
I have a 944 S2, if it would similarly work for that too, I would love to order one of these as well.
Old 08-29-2020, 01:08 PM
  #277
Ed Scherer
Ed Scherer's Avatar
I'm not 100% sure, but I think the 968 should work. You can see from the posts starting at post #262 that it's a nicely isolated rheostat that's similar to the 928.
I don't know for sure whether st0ppy ever got a unit and installed on a 968.
The main configuration that won't work is a dimmer rheostat that's part of a headlight switch / instrumentation lighting dimmer combination where one side of the rheostat is internally connected to other circuitry and can't be isolated ("can't be isolated" in the sense that there aren't two rheostat terminals that aren't connected to anything else).
I'm hoping that others with more knowledge about 944s will chime in here.
Old 08-29-2020, 03:19 PM
  #278
Alan
Electron Wrangler
Alan's Avatar
It will work for a 968
Alan
Old 08-30-2020, 11:34 PM
  #279
ktonini
ktonini's Avatar
Awesome! Can confirm the 944 S2 looks exactly like the 968 in post #262.
Any chance you have that kit in stock?
Chennig944 (09-15-2020)
Old 09-03-2020, 04:21 AM
  #280
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
What about front lighting w/ a string of LED's?
Pick up a string of lights, put them up,
wait for sunset, and check out the look.
i front lit my instruments 12 years ago.
fantastic presentation, perfect light level ....
a blissful, life changing event.
Old 09-03-2020, 04:27 AM
  #281
ktonini
ktonini's Avatar
I actually did exactly that, but just need to be able to dim them a bit more than the built in potentiometer allows.
Old 09-15-2020, 12:46 AM
  #282
Chennig944
Chennig944's Avatar
Hi Ed, I'd love to grab one from you as well for my S2. Hope to hear from you soon!
Old 09-15-2020, 01:13 PM
  #283
Ed Scherer
Ed Scherer's Avatar
I'm unable to PM you; I think you must need to have a certain number of posts before that's possible.
For you 944 S2 guys, based I what I see in post #279 in this thread, either the "AILD-1 connection kit for '90-'95 Porsche 928 (soldering required)" or the "AILD-1 connection kit for '90-'95 Porsche 928 (crimping required)" should work. If you're comfortable soldering, that first option makes for a cleaner, nicer installation.
There's more potentially useful information in post #168.
Old 09-16-2020, 08:36 AM
  #284
PC-85-928S
PC-85-928S's Avatar
Default Question
In your experience-
Do most cars benefit from a unit which adjusts 50% up or 50% down?
Old 09-16-2020, 11:05 AM
  #285
Ed Scherer
Ed Scherer's Avatar
Originally Posted by PC-85-928S
In your experience-
The fade up or down configuration parameter is only for what it does at power-on. For 928s, the unit first sees power when you switch the parking or headlights on. At least on '89 and later (perhaps before that, too; I'm not sure), when the headlight switch is position 0 (head/parking lights off), the instrument cluster backlighting is on, so it makes most sense to fade down from 100% (since that's where the instrument cluster backlighting is starting from) to a level based on the rheostat setting. It's a very minor detail that really doesn't matter that much.
The "50%" you might be referring to is just what happens if the rheostat is or becomes disconnected. It just guards against the instrument cluster going dark if there's an unexpected wiring or connection problem.
There's no reason I can think of to select anything other than configuration "G1" for any model year 928.
Quick Reply: PWM dimmer for instrument backlighting after upgrading to LEDs
