928 Forum 1978-1995
Sponsored by: 928 Specialists
Duc's Hybrid build
Old 12-18-2011, 04:08 PM
  #91
Ducman82
Ducman82's Avatar
just ask for an OB pan and pick up set up? he will know what i mean i take it...
Old 12-18-2011, 04:15 PM
  #92
blown 87
Rest in Peace
blown 87's Avatar
That is what I did, told him I was going to convert from a later model.
Old 12-18-2011, 04:25 PM
  #93
justaguy
justaguy's Avatar
yes Mark will know what you are talking about. Greg brown has the pan spacer. I would recomend running one of those as well as long as your budget permits it. If you run the spacer you will also need to install a mini starter as the stock starter will not clear the lowered oil pan. You will probably have to die grind the pan to get clearance for the top starter bolt as well. That's what I did.
Old 12-18-2011, 04:30 PM
  #94
Ducman82
Ducman82's Avatar
got the spacer from Greg. just need to figure out what pan/pickup i want. mini starter for sure is on the drawing board. big on right now is do i use this silicone gasket. wish it had "stops" around each stud so you don't over tighten it...
Old 12-18-2011, 04:40 PM
  #95
justaguy
justaguy's Avatar
I used the porsche gasket between the spacer and the block and a loctite flange sealent . between the pan and the spacer. Worked well and I have no leaks I forget the Loctite number but my mechanic called it turkish delight because of its colour and smell. I could get you the number but I am leaving for 2 weeks for the holidays. Back in early january.
Old 12-18-2011, 04:46 PM
  #96
Ducman82
Ducman82's Avatar
i have some of that. it will go between the block and spacer for sure.
Old 12-18-2011, 06:07 PM
  #97
IcemanG17
IcemanG17's Avatar
Yup Loctite 574 (or 547??) comes to mind....I did the same thing.....loctite between spacer-gridle and the stock cork gasket between oil pan-spacer...... I had some leaks with the silicone gasket, probably due to over tightening and it "squirting" out....so of course my answer is to "tighten it more".....
Old 12-19-2011, 05:51 PM
  #98
Ducman82
Ducman82's Avatar
order up the OB pan stuff from Tom at 928Intl.....
here is a odd question. any pan mods i should do whilst its off? i was thinking of adding some AN fitting for future use as oil returns or somethings..... hummm
Old 12-19-2011, 06:07 PM
  #99
mark kibort
mark kibort's Avatar
the pan spacer is not needed. dont worry about it. all you are doing is having to put more oil in the sump, and have more oil to climb the walls in to the crank area under high g loading, cornering and accel. Plus, forget about having a half inch lower pan!! . I would never do it, never never never. I can point out 5 races and 3 street events where i would have lost the mtor or did damage if my pan was .5" lower. I have never had any pick up issues, nor has brian before he put the pan spacer on. there is a good chance you will create more problems than you will solve with it, thats almost a guanteee.
Old 12-19-2011, 06:17 PM
  #100
mark kibort
If you got it already, i would go with the OB pan and screen set up. brian has it working, and I dont know if the newer set ups would lke that extra oil mass sloshing around.
Old 01-10-2012, 11:54 PM
  #101
Ducman82
Ducman82's Avatar
OB style pickup and screen installed. GB windage trays assembled and installed. spacer on, bolted up. BAM.
Old 01-11-2012, 12:00 AM
  #102
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,776 Likes on 1,350 Posts
Porny ****. Nice!
Old 01-11-2012, 12:01 AM
  #103
BC
BC's Avatar
Thats pretty.
Old 02-27-2012, 02:31 PM
  #104
Ducman82
Ducman82's Avatar
going to be ordering up some parts today to try to wrap the long block up.. question for you guys, when i install the lifters, how do you clean and prep them? I'm just wondering because when i get it all together to check valve clearance, won't a pumped up lifter make a difference?
Old 03-01-2012, 08:18 PM
  #105
Ducman82
Ducman82's Avatar
installed a new lasco pump, and a Porktensioner...
Quick Reply: Duc's Hybrid build
