The build a 928 boat thread.
#31
Funny you say that...when I was looking at the Engine/Air Inlet Pics, the first thought was Dave is going to need at least some sort of braces at the front of that airbox to somewhere on the engine/block/heads. I hadn't thought about the bouncing, but just the air drag alone will break the rubber mounts on the Air Guide.
So yeah, you should do some sort of rubber mounted supports for the "offshore airbox"...I would do front and rear supports from the corners of the airbox if it were me.
OH, and dump the factory air filter for a K&N type 928 Filter, it will hold up better with all the moisture.
Cheers,
Dave
Cheers,
Dave
I agree that the airbox will need some addtional mounting points. The picture was taken during a test fit. It took a lot of trial and error to get a design that would give me the same cross sectional area has the stock inlet yet still go on and off without taking anything else apart.
The (poorly worded) question I was asking was will there be a negative effect on the assembly shown below in red?
#32
Interesting question. I've never worked on or seen CIS apart, but I'm glad to offer an uninformed opinion. The rectangle at the right end of your red circle is a counterweight to balance the mass of the plate and lever, so up/down accelerations are inertially balanced and skipping along the water won't move the air flow sensor. Porpoising might have an effect, but you'll trim the boat out of that. If the bow rises when running, the mixture might change a little (rich?), like driving up a steep hill. So maybe you're thinking adjust the mixture with the boat on the trailer with the bow up at about the running pitch?
#33
Rennlist Sponsor
Dave,
But, roads are not smooth and jar free and have lots of sharp impacts etc...so I would would put that worry on the "B" list for now....or at least until you get some water time to see if you have running issues under harsh conditions.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
#34
I'll try to post pictures of the various components that are going into this project. These pictures show the parts that will take me from the 928 crankshaft to the splined jet pump shaft. The original Porsche marine kit was set up for use with an inboard/outboard drive so I put some of those parts on the shelf and created some new parts to suit my application.
#36
I have been monitoring Performance Boat , Scream & Fly and Boat Freaks.
There is a lot of usefull stuff on the forums.
#37
An update 7-7-11
The project moves forward....
While I am waiting for my fiberglass guy to visit and give me an opinion on restoring the exterior finish, I cleared a spot in the garage and brought the boat indoors.
The trailer is a project in itself and since it's basically a big lump of welded steel structurals, I can refurb that without much trouble.
The first step was to get the boat off of the trailer so I made simple cart that has heavy duty swivel casters, brakes and proper support for the hull.
#38
I tied the boat to a solid anchor ( car lift posts) and pulled the trailer out from under it. As the trailer came out, I slid the cart under the boat.
Here is the boat resting on it's new cart. It moves around very easily and will probably stay on the cart for the duration of the project.
#40
Here is the trailer....pretty basic. It will get sandblasted and then epoxy coated in black. I'll probably just buy a set of chrome fenders for it. The hubs and brakes will be rebuilt and the axles will be widened so I can run the deep offset 928 wheels.
#41
Before I tear the trailer apart, I did some trial fitting of the 928 wheels so I could measure for fender and boat clearance.
Working with what I have "in stock", I'm looking at phone dials and 10x18 turbo-twists. The turbos have 285's mounted and might present some clearance problems. I need to keep this narrow enough to get through the garage door.
I also think the phone dials are more in keeping with my intended 928 theme.
#43
Craic Head
OLD SCHOOL BABY! Gotta be the phone dials!
Love this thread!
BTW- Will the cart still be OK when you put the engine in and the center of gravity shifts or will it be back on the trailer by then?
Love this thread!
#44
It might be nice to run 15 inch phone dials....there is a much better trailer tire selection and less expensive than 16 tires. I tend to prefer running real trailer tires for a number of reasons......including that the higher sidewalls smooth out the ride and beat up the boat less and they track better than auto tires due to their construction.
#45
I agree with all of the above but...I'm giving up a little practicality for the sake of design. My gross weight should be well under 1,500lbs and I'm spreading that over 4 wheels.
The reason I selected 16" is that I have a 10 of them here already and I would have to buy 15" if I wanted to switch. Same story with the tires. I have a few sets of tires here that are dying of old age rather than wear.
