BSFC ?
Rest in Peace
If you want a exact number, then you need to pull your engine and see the folks that have the engine dyno that Greg Brown uses, otherwise some where between .38 and .50 will get you in the ball park.
What I would like to know is the BMEP on a single motor making 400 HP with boost, and one that made that with N2O, and I mean pressure spikes and all.
I think if we had accurate numbers on both, it would go at least go a foot or two on ending that question.
Administrator - "Tyson"
Team Owner
http://en.wikipedia.org/wiki/Brake_s...el_consumption
Check the owners manual it may have more info on fuel consumption
..and I didnt prevent anyone from posting an answer within 50yds of what his car may be running at.
I'd expect you jumping into a -ton- more forums if levity was suddenly against the rules.
Rest in Peace
Just think about it, Gretch was his role model, and Randy beat them both, daily, so he has little time for you........
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Geeeeezzz! Sorry for blowing up!
I'm trying to make some determinations about this goofy supercharger project of mine, and a good BSFC number would help a lot toward the calculations I'm trying to do.
I thought that Porsche had published BSFC numbers for some of their engines but I am having no success in unearthing one for the 928 engine.
Thanks, though........
Rest in Peace
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
784 Kirborts, that was funny!
Tomato Shields UP!
Ive done all these types of calcualtions...read a few hot rod tuning books in the library etc etc..blower rpm...delta T etc etc.. In short, just bolt it up and don't worry about the math and physics of it. You will get more results from a proper tune than trying to figure out what you WILL get ahead of time on paper. most critcal thing in a math sense will be the blower rpm and pulley speed...you dont want to over speed the blower. You will kill bearings and efficiency.
8-10 psi intercooled boost will get you 430 and up at the wheels.
1.21 Gigawatts?
