another gts block question
do GT cylinder heads fit on and work ok on a GTS block?
are there any other differences in the GTS block/pistons/crank which would stop it being a direct replacement to drop into a GT?.
GTS and GT are both ROW versions.
thanks in advance
Phil
90gt
thanks in advance
Phil
90gt
Phil,
You could use a GTS crank, rods and pistons in a 5L block and it would work. You could also use an S4 or GT crank, rods and pistons in a GTS block and it would work. But you cant mix a 5.4L crank with 5.0L rods or pistons.
Former Sponsor
do GT cylinder heads fit on and work ok on a GTS block? Yes.
Are there any other differences in the GTS block/pistons/crank which would stop it being a direct replacement to drop into a GT?. No.
GTS and GT are both ROW versions. All GTS blocks are the same. All GT blocks are the same. No changes in the blocks to send the engines different parts of the world.thanks in advance
Phil
90gt
Phil
90gt
thanks gents,i will be stripping the engine over the comming weeks to see if indeed the bore of the block is damaged-spark plug was out when the fire started-,so has been stood for a few months with water/debris sitting in the bore.
still the car itself is looking slightly better than the burnt mess it was.
happy 928 motoring to all
Phil
90GT getting there
88SE 99% there
Phil
90GT getting there
88SE 99% there
