928 Forum 1978-1995
Sponsored by: 928 Specialists
Euro head spring cup issue....
Old 05-05-2011, 08:41 PM
Ducman82
Ducman82's Avatar
Default Euro head spring cup issue....
anyone ever run in to this? inquiry in with Roger (got parts from him)
the springs fit in the cup great, but the cup does not sit in the head........
Old 05-05-2011, 09:22 PM
RCinXS
RCinXS's Avatar
There are two dfferent style spring cup and retainers. Also different springs.
Old 05-05-2011, 10:18 PM
Dave928S
Dave928S's Avatar
My 82S M28/11, which is 40 engines up on the introduction, has all those alterations. The tell tale without taking anything apart is the different valve stem seals (if they're original and haven't been replaced).
Old 05-05-2011, 10:56 PM
Ducman82
Ducman82's Avatar
ya i got the heads from BC bone bare.... not even guides...... so i have no idea. well im guessing i have old heads, with new style new parts.....
Old 05-05-2011, 11:04 PM
Ducman82
Ducman82's Avatar
another quick question. does anyone know how deep to set the valve guides?
Old 05-05-2011, 11:25 PM
Dave928S
Dave928S's Avatar
Valve guide installation needs to be done very carefully so that you don't crack the heads.
Check the guide bores to make sure there is no galling/damage of the bore. The old guides should have been reamed out, and then the last bit of the shell removed to avoid damage to the head.
New guides are oversize and need to be machined down to give a couple of thou oversize press fit. The guides can then be chilled and the head heated to easily press them in and achieve a shrink fit without damage. Once they're in, they need to be reamed concentric to the seat to suit the valve stems, and the seats recut/cleaned up. Valves need to checked and cleaned up in the process, springs tested/replaced, and then the valves installed and shimmed as per WSM spec, to give correct height and seat pressure.
Print out the WSM sections related to this and give them to the shop doing the work, and emphasise the procedure regarding pressing in new guides. A 928 savvy shop won't have a problem but others might assume they don't need to be so careful.
Old 05-05-2011, 11:35 PM
BC
BC's Avatar
Yes - please please please do make sure that when you go to someone to put the guides in they simply to not install them with a hammer. I personally removed the guides and made sure to remove them with no hammering at all. The guides bores were not galled.
I had a monkey install guides in a set of early heads once and they cracked the boss in the port. Much crap ensued.
Old 05-05-2011, 11:37 PM
BC
BC's Avatar
Hot head, chilled and oiled valve guide is the installation pattern right?
Old 05-05-2011, 11:53 PM
Ducman82
Ducman82's Avatar
thanks guys, ill go did in the WSM tomorrow, should be in there somewhere... :-) now looks like i need new cups
Old 05-05-2011, 11:56 PM
Dave928S
Dave928S's Avatar
I have the appropriate pages copied somewhere ... I'll have a search and try and post confirming information a bit later in the day.
Old 05-06-2011, 03:21 AM
Dave928S
Dave928S's Avatar
Just searched and all the dimensional information you need is in the dimensions and tolerances publication. Back that up with the appropriate sections of the WSM and you have everything you need.
The dimension and tolerance docs for all years are on the Jim Morehouse CD's. Let me know if you can't get hold of the D&T PDF for your car and I can email it to you.
Old 05-06-2011, 04:09 PM
Ducman82
Ducman82's Avatar
anyone possibly have the part numbers of the "old style"? cant seem to find them anywhere... :-(
Old 05-06-2011, 06:06 PM
BC
BC's Avatar
I sent the springs to you - and they have the spring seats that cam with the heads.
Old 05-06-2011, 06:19 PM
Ducman82
Ducman82's Avatar
nope. valves, springs, heads. that be it :-P looks like machining is in the heads future, cant seem to find the "old style" stuff.
Old 05-06-2011, 06:28 PM
BC
BC's Avatar
No - I specifically remember - the spring seats are simply the shims that were in the zip lock bag with the springs.
Quick Reply: Euro head spring cup issue....
