16V air pump delete -what to do with the fittings on the heads
Just buy the right plugs and crush washers from a vendor ... they're cheap. The standard plugs are plated steel with an aluminium crush washer. Here are two pics ... one of the open back air pump hole and the matching plugged front one.
did you get the fact that the fittings on the back of the heads are not the air pump plumming, but the cold start injection system? do not remove!!
unless this is a euro, then plug away with the standard parts. the front of all 928 heads have these plugs.
euro heads ports are tapped to the exhaust ports
US heads ports are tapped to the intake ports.
putting euro heads on a US system , will result in tossing gas into the exhaust for that flame throwing effect.
Am I going to be able to install these easily with the motor in the car? I have very small arms and can reach into some odd places. I would go out and look at this on my car but it is raining and I am at work.
-edit- just saw all the other posts. I do not have a euro but am trying to get rid of my air pump. Just need to know what I need to cap off and such.... Kinda confused atm about what I need to be looking for and blocking off.
From: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
