Hood won't open
You can open it from under the bumper. Long screw driver, straight up and pry the latch.
Sometimes the cable has slipped at the latch wire nut, meaning the 3" travel of the handle isn't enough to trip the release. The handle inside cabin will come off the post that it levers against and you can pull the cable directly rearward, if you haven't tried this already.
It's really easy if your grill has fallen out! ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
OOPS! That's WHY my grill fell out; I was reaching through to open the hood!.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Attachment 526242
![order](https://rennlist.com/forums/graemlins/order.gif)
Attachment 526242
The plastic can just be pushed slightly aside then you have straight shot from underneath with long screwdriver to save your arm. Flashlight still helps though
[QUOTE=SeanR;8446617]You can open it from under the bumper. Long screw driver, straight up and pry the latch.[/Q
Did the pry side to side, hood is up. Now, how do I tighten the cable so this doesn't happen again????
You can either adjust inner wire at the latch (it's held by grub screw) but this requires drilling out rivets and removing latch.
Far easier is to adjust the at the clamp right next to ignition amplifier. I'm pretty sure you can take out slack there.
[quote=Jbws86928;8843043]
Now that you know the trick, just keep doing it that way.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Sorry, just reminiscing about my PO.
