fuel distributor relief valve
ok my relief valve seems to be missing a O ring!
can someone tell me if there should be an Oring at #1 in the pic
and also if i need to fight with the allen screw at #2? is there a oring inside also.
Thanks, Steve
Thanks, Steve
karl, i believe there should be two as well. i read some posts by dennis stating there's two, i guess i'll wait and see what dennis knows about this. thanks
Are you sure the o-ring is not still in the fuel distributor hole this came out of.
The small o ring (in the ebay pix) goes on the end of the valve and the large o ring goes into the #1 slot. Don't forget the crush washer. The spacers supplied in the kits are for adjustment of the system pressure. If your system pressure was originally OK, use the old spacers.
Dennis
Dennis
