928 Forum 1978-1995
Sponsored by: 928 Specialists
Trans kickdown relay debugging
Old Feb 23, 2011 | 01:18 AM
Speedtoys's Avatar
Speedtoys
Default Trans kickdown relay debugging
88 S4, Auto
I dont seem to have a functioning kickdown setup...
The tranny shifts fine, but at WOT it'll shift a tad early..not too hard or anything, but just doesnt seem to have that signal from FULL wot to shift at really high RPMs rather than the normal not quite WOT, that exists before you hit the relay switch.
What components do I start debuggin or testing?
Old Feb 23, 2011 | 01:45 AM
borland's Avatar
borland
this thread might help...
https://rennlist.com/forums/928-foru...-5k-or-so.html
Old Feb 23, 2011 | 01:50 AM
Speedtoys's Avatar
Speedtoys
Awesome..will be all over those things.
Old Feb 23, 2011 | 02:38 AM
IcemanG17's Avatar
IcemanG17
if you want it to shift a touch higher in the rpm try increasing the tension of the bowden cable.... My stock 88 that was running well would shift every gear at 6000-6200.... I would cruise around the track in 3....then use kickdown to power out of corners...it was fun!!! At least it sounded great!!!
Old Feb 24, 2011 | 02:33 PM
Speedtoys's Avatar
Speedtoys
Ok..the bowden is tight to the tranny, maybe a little too tight, the trans reacts on throttle quicker.
However..no kickdown relay action.
I can HEAR it click under the pedal, I can feel it click..but theres no action with it.
I guess, crawl under there see if its plugged in??
Old Feb 24, 2011 | 04:13 PM
borland's Avatar
borland
Test the kickdown solenoid for proper operation with the throttle kickdown switch, but without the engine running. From post #10.....
"Open the passengers side door, with the ignition key on push the gas pedal to the floor you should here a click by the door."
https://rennlist.com/forums/928-foru...wn-switch.html
Old Feb 24, 2011 | 04:41 PM
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Is the gas pedal contacting the kickdown switch? This happened to mine and I had to adjust the ball & cup socket behind the pedal.
Old Feb 24, 2011 | 05:39 PM
Landseer's Avatar
Landseer
Here's what the electric solenoid valve looks like, center / low on rear of trans near x-member
File Type: jpg
7 Porsche Models That Have Aged Like Fine Wine
Old Feb 24, 2011 | 05:49 PM
Speedtoys's Avatar
Speedtoys
First think I'll do after work, is this.
Where is this relay that I'll be listening for, located?
Old Feb 24, 2011 | 06:31 PM
SteveG's Avatar
SteveG
On the CE panel, relay XV is bottom row, seventh from left.
Old Feb 24, 2011 | 06:59 PM
supercedar's Avatar
supercedar
I had a similar problem. The side panel (console) screw was loose down by gas pedal, which would push the pedal away from kickdown switch when I would apply pressure. Tightened the screw and all was fine.
Thomas
Old Feb 24, 2011 | 07:43 PM
IcemanG17's Avatar
IcemanG17
there are two parts to the circuit....the switch itself under the gas pedal can fail & the solenoid that plugs into the trans can also fail....typically its the switch under the pedal.....
One of my favorite things to do in sharky was to cruise along at 60mph......rpms at a lowly 2200.....then drop the hammer....a quick DOUBLE downshift...BWAAAHHHHH and your GONE..... :>)
I knew I had a strong 928 when I did this during the test drive with Susan from Devek....her response was "wow, this one is strong!"....many years later I figured out its 279whp...she was right
Old Feb 24, 2011 | 07:57 PM
Speedtoys's Avatar
Speedtoys
Ice:
Well, I'll go on the rollers at Thill next weekend with A/F, to see where my efforts have gotten me so far.
Old Feb 24, 2011 | 10:56 PM
928 at last's Avatar
928 at last
Default Mine was not
Mine was a problem too. Tab on the pedal wasn't contacting without putting waaayyy too much force on the WOT position.
Then I intalled a manual bypass, and although adusted, I don't care anymore......
Old Feb 25, 2011 | 01:51 AM
Speedtoys's Avatar
Speedtoys
Ok.
Switch under pedal is getting depressed.
Switch works..tested with meter.
No voltage between the two plug leads..Id assume there is SOME voltage there being crossed coming from the harness, right? (with key on of course)
And the kickdown relay..no noise or anything from it, no life at all when the kickdown button is depressed. PUlled it, contacts were clean, are cleaner now..but relay has zero action.
What fuse might I look at?
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
