928 Forum 1978-1995
Sponsored by: 928 Specialists
Trans kickdown relay debugging
Old Feb 25, 2011 | 02:05 AM
Speedtoys's Avatar
Speedtoys
Duh me.
Fuse #10.
Sorry bout that...left it there and here..for future idiots that should search.
And thats not it..cuz I have the rest of the devices that this fuse services...grr.
Old Feb 25, 2011 | 02:08 AM
Speedtoys's Avatar
Speedtoys
I guess tomorrow while on the alignment rack, I'll look at the solenoid in the back.
Nuts..so far on this.
Old Feb 25, 2011 | 09:52 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Wink
Power from the 15 bus (ignition switched power) flows to Fuse #10; from Fuse #10 to Terminal B14; from B14 on a black/violet wire to the kickdown switch.
If you have no power at the kickdown switch, there is no point in checking any further until you get that fixed.
Terminal B14 will be the next-to-the-top terminal on the left side of Plug B, which is the 2nd plug from the left end. If there is no power on B14, pull the Central Electric Panel and find the disconnected/broken wire between B14 and Fuse #10. It will be gray...
Old Feb 25, 2011 | 10:35 AM
Landseer's Avatar
Landseer
^^^^ Its like a soothing voice from above when he weighs-in!!!!
Old Feb 25, 2011 | 10:40 AM
Speedtoys's Avatar
Speedtoys
Old Feb 25, 2011 | 11:26 AM
Speedtoys's Avatar
Speedtoys
Yannow, I never checked for 12v from the under pedal plug, but I have 12v at B14, and at the kickdown switch..and when I press the switch I get 12v on the other side as well.
When I trip the KD switch, I get 12v at terminal 30 of the relay plug on the CE panel..so thats a good return path.
Maybe I should shop out a relay...
I have the relay apart, and its very clean...no issues mechanically inside it at all.
SO..if the kickdown switch mod would force this relay open, because without that 12v, the relay is normally closed..with it, it opens.
With the relay case open, a visual inspection with the KD switch pushed..shows no visible opening of the relay.
So..force the relay open and see what it does?
We'll try that...since thats all this 12v feed to the thing does at terminal 30..is energize the coil and open the contacts.
Old Feb 25, 2011 | 11:34 AM
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
That's good advice. Pop a new relay in and go for a ride. It may start working again.
Old Feb 25, 2011 | 01:50 PM
WallyP's Avatar
WallyP
"So..force the relay open and see what it does?
We'll try that...since thats all this 12v feed to the thing does at terminal 30..is energize the coil and open the contacts. "
Ummm - no.
The kickdown relay does not cause the transmission to kick down. The 12 vdc thru the switch under the throttle provides power to the contacts in the relay, not to the coil. That power on Terminal 30 flows thru the NC (Normally Closed) relay contacts to the kickdown solenoid on the transmission.
The function of the kickdown relay is to momentarily open those NC contacts at max RPM. This drops the kickdown solenoid to normal operation, causing the transmission to instantly upshift. As soon as the RPM level drops in the next gear, the relay drops out and the NC contacts close, putting the transmission back into kickdown mode.
With the car in a quiet place, pull the kickdown relay and locate Terminal 87a in the socket. Use a jumper to momentarily apply and remove 12 vdc to 87a. Each time that you apply/remove the power, you should hear a "click" from under the car. If you hear no click, either the circuit from 87a to the solenoid is broken, or the solenoid is faulty.
7 Porsche Models That Have Aged Like Fine Wine
Old Feb 25, 2011 | 02:17 PM
Speedtoys's Avatar
Speedtoys
*heh*
Electric Jesus has spoken.
Thanks! Will do that at the shop this afternoon.
Old Feb 25, 2011 | 07:21 PM
Speedtoys's Avatar
Speedtoys
Wally:
Fed 12v to 87a, no click at all out back.
Old Feb 25, 2011 | 07:41 PM
Landseer's Avatar
Landseer
I'd be looking for 12V at the solenoid harness with a helper standing on the gas pedal.
Old Feb 25, 2011 | 07:53 PM
Speedtoys's Avatar
Speedtoys
Ya...thats next...
Old Feb 25, 2011 | 07:56 PM
Speedtoys's Avatar
Speedtoys
Originally Posted by Landseer
Here's what the electric solenoid valve looks like, center / low on rear of trans near x-member
I see this in the drawings..gonna be a bear to get that out?
Old Feb 26, 2011 | 12:47 AM
WallyP's Avatar
WallyP
Put your jumper from 12 vdc to 87a and check for power at solenoid. If you have power but no click, time to pull the solenoid.
Old Feb 26, 2011 | 03:50 PM
Speedtoys's Avatar
Speedtoys
Tranny fluid is way low, gonna solve that first, before I get to the solenoid..which I did find, and only has 1 wire going to it..guessing it grounds via the tranny itself.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
