928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 03-13-2017, 08:22 PM
  #6946
Geo55
Geo55's Avatar
Started my timing belt project. Found the teeth shiny on the cam sprockets. And a nice pool of oil next to the motor ID number. Soaked some up, recess was full.
Old 03-14-2017, 02:07 PM
  #6947
Hymodyne
Hymodyne's Avatar
Got my clutch discs back, relined by Tampa Clutch.
James
Old 03-14-2017, 02:15 PM
  #6948
bureau13
bureau13's Avatar
Really interested to find out how well this worked out, as I will at some point need to do a dual disc clutch...
Old 03-14-2017, 05:29 PM
  #6949
polecat702
Vegas, Baby!
polecat702's Avatar
Disconnected the battery, and put the cover back on. I'll be sitting a while, I'm back to work. Retirement wasn't that great, boring actually. Plus the money that's been offered was to good to turn down.
Old 03-14-2017, 10:10 PM
  #6950
soontobered84
soontobered84's Avatar
Damn Joe!! You can't take it with you. I thought for sure you'd be down by the river in Blanco or somewhere in the Hill Country. I don't know anything about retirement and I'll probably never be able to retire but I'd get probably get bored, too.
928 content:
Moved the GTS outside so I can take it in the morning to the Mercedes specialty transmission shop down the street to check pressures and find out what is wrong with this replacement transmission for free.
Moved the 89 to the ramp lift so i can replace leaky transmission line
Moved the Stepson outside now that I know the fuel pump is functional.
Old 03-14-2017, 10:16 PM
  #6951
Petza914
Petza914's Avatar
Received 6,503 Likes on 4,139 Posts
Can't take it with you, but you can buy GTSs
Old 03-15-2017, 04:20 AM
  #6952
polecat702
Vegas, Baby!
polecat702's Avatar
928 content:
John,
Dee had me working harder here at the house, than in the oil patch! I need a break! LOL.
I'm in the process of restoring my El Camino, the Polecat is a money pit, always has been.
Plus we're re-landscaping the property to very low maintenance desert landscaping. Re-stucco, and paint. Replacing the courtyard walkways, and entrance concrete, with Flagstone. Tearing out all the tile in the main house, replacing with hardwood flooring. We're adding a solarium to the back of the main house, a outdoor kitchen, and pergola by the pool. Plus a new spa.
As far as my 928. I got lucky with the tranny I bought from LA Auto Parts. It shifts better than the original, that went south in front of the house, and it don't leak! I need to change all the hoses on the car, and do an intake refresh. Plus I'm adding some performance parts to it. Gonna try to get it repainted before Parade in July, so it's pretty for 3rd coast.
It all takes money, why not let Baker Hughes, pay for it? This way I don't have to touch my stash!
Old 03-15-2017, 04:44 AM
  #6953
BigCavolo
BigCavolo's Avatar
Thought about my 86.5. It's on a spa vacation at TPWS in Austin. Maybe in May I'll be here posting: "Picking up my 928 today!"
Thanks for posting all the things I wish I could see.
Old 03-15-2017, 06:23 AM
  #6954
The Forgotten On
The Forgotten On's Avatar
Did a trans fluid change on the 89 today. I learned how much of a pain the dual exhaust system used post 86 is to deal with when doing this.
It just gets in my d*mn way
It makes the 81 a cake walk in comparison.
Old 03-15-2017, 03:24 PM
  #6955
soontobered84
Joe,
Sounds like she was trying to keep you so busy you wouldn't have time to get in trouble! LOL
If Baker Hughes will give you the kind of money that it will take for those kinds of projects, by all means take it to the bank!!
And get some rest!!
Old 03-15-2017, 05:10 PM
  #6956
928NOOBIE
928NOOBIE's Avatar
Got it's new ceramic-coated MSDS headers installed...and has flat bedded over to the exhaust shop, where it will get a custom stainless steel exhaust..starting with an h-pipe about 6 inches back from where the pipes split to go to the header collectors, a custom X-pipe in the location reserved for the factory resonator, and a NOS muffler...
This is an early '86 car, so the exhausts both go down the drivers side of the car. I'll be posting pictures of this because I found very little information on aftermarket set ups for our early '86 cars....really looking forward to the finished product...I checked my dates and I ordered the headers from DR back on 7 January....
I'll have pics up in this thread and the thread we have rattling around somewhere showcasing what folks have done with other custom set ups.
Old 03-17-2017, 10:18 PM
  #6957
G.P.
G.P.'s Avatar
Reinstalled my front splash shields after gluing some metal on to strengthen the mounting holes.
And I did some cleaning around the wheel arch while the splash shields were off.
Old 03-18-2017, 04:11 PM
  #6958
John L. Gormley
John L. Gormley's Avatar
New Timing Belt, water pump, rebuilt tensioner, and oil gear, plus new tensioners and other rollers, main seal and oil pump seal. Waiting on new tensioner bolt from 928sRus to finish up
Sent from my iPhone using IB AutoGroup
Old 03-18-2017, 05:55 PM
  #6959
C531XHO
C531XHO's Avatar
Default Another one of those days - 1 bolt in 3 hours
Spent 3 hrs on the beast today;
  • Failed to undo the front disc screws; impact driver, heat, angle grinder - gonna sneak up on the bolts with a drill tomorrow tee hee
  • Failed to remove the sticking starter motor - left the extended allen keys at home, miles from the garage.
  • Managed to remove one of the 2 near side brake calliper bolts. Car is on stands and didn't have enough room to swing the breaker bar, car on stands too close to wall to get in the an give it some...
[*]Found out the couriers aren't going to deliver my brake pipes, said they had tried 3 times this week but I work from home and am sure they didn't ring. Got everything else I ordered in the week. Couriers sent brake pipes and pipe bending tool I was planning to use on the fuel lines this weekend back to the vendor..
[*]Tooled up for tomorrow!
[*]Placated myself by ordering many parts...
UPDATE - reason the calliper bolt wouldn't come off is that I was doing it up rather than undoing it - lesson to self, if you are upside down/back to front working on bolts, check!
Old 03-18-2017, 08:45 PM
  #6960
Mikebte
Mikebte's Avatar
New AC compressor and AC lines installed. Ready for vacuum and recharge. Installed injectors and all new fuel hose and started. No leaks.
Lost a hood bolt, so I have to find another.
Quick Reply: So what did you do to your 928 Today......
