928 Forum 1978-1995
Sponsored by: 928 Specialists
Name this noise (engine tick)
Old Jan 26, 2011 | 01:50 PM
  #31
leperboy's Avatar
leperboy
Originally Posted by BC
Sure as hell sounds similar.
I've had the same sound on startup after the car sat for a while. Lifters. It can be surprisingly (and frighteningly) loud. It went away after about ten minutes of running. I added a quart of auto transmission fluid with the oil on one oil change to help.
Matt
Old Jan 26, 2011 | 01:55 PM
  #32
SeanR's Avatar
SeanR
I use Marvel Mystery Oil in mine when the lifters start to stick.
Old Jan 26, 2011 | 01:57 PM
  #33
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
I was going to try the ATF solution but chickened out. How long do you run the car for (mileage interval) prior to changing out the oil with that quart of ATF in it?
Old Jan 26, 2011 | 01:58 PM
  #34
mark kibort's Avatar
mark kibort
the frequency is every other revolution? contrary to another poster, the frequency is not that fast, if its a rod knock, its every revolution, if its a stuck lifter every other revolution. big diff. you should rev it up on the video. lots can be heard with increasing RPM. go under the car and see if you can hear it down low by the pan. I had a real loud stuck lifter when my car was transported to Road america. i guess all the bouncing around , drained the lifters. took about 30mins to recover, but it sounded REALLY scary bad and then it went away.
Old Jan 26, 2011 | 02:01 PM
  #35
mark kibort
that was exactly what mine sounded like at RA. yep, lifter, and let it run, and it will go away when it pumps up.
Originally Posted by AO
Stuck lifter... or one that has lost its oil. How long have you run the engine like this?
Remember this? It was lifters. Cure was to let it run!
Old Jan 26, 2011 | 02:04 PM
  #36
AO's Avatar
AO
Supercharged
I'd say 50 to 100 miles and I wouldn't do any high revs - keep below 4k.
Old Jan 26, 2011 | 02:49 PM
  #37
Bill Ball's Avatar
Bill Ball
Under the Lift
Originally Posted by Big Dave
Conceivably, yes, but you'll spray oil all over the place.
Actually very little oil sprays out. If you rev it, it will throw some off the cams, but otherwise it can be done w/o creating a big mess. We did this to Dennis Kao's motor once when we were trying to diagnose wierd oil pressure behavior.
Hopefully that lifter will get unstuck and pump up again.
Old Feb 3, 2011 | 02:56 PM
  #38
BC's Avatar
BC
I am updating the threads I opened in the first week of ownership of the car. The noise is no longer audible during normal driving or idle. I do not believe I have heard it since the first time I drove it over 1 mile.
I have not changed the oil, but I will this weekend. I will also note here that I put half a can of seafoam into the oil pan before what has amounted to about 150 miles of driving so far.
Thanks for everyone's assistance.
Old Feb 3, 2011 | 03:15 PM
  #39
Herman K's Avatar
Herman K
Default Rislone or Marvel oil should give you results in just a few minutes
I've always used "Rislone" with great results in my MB diesel whenever I had a loud or stuck lifter.
http://www.youtube.com/watch?v=Q6A15dhtJN4
Good luck
