928 Forum 1978-1995
Sponsored by: 928 Specialists
Who wants to be the next caretaker of Leeroy
Old 01-13-2011, 08:54 PM
Ducman82
Ducman82's Avatar
throw my name in the hat, id love to fly down there! :-)
Old 01-13-2011, 09:08 PM
Jadz928
Jadz928's Avatar
Originally Posted by mark anderson
Yes the clutch issue has been resolved.
Fantastic! So, what was it... release arm bush?
Old 01-13-2011, 09:50 PM
robot808
robot808's Avatar
That is awesome that BC fixed the clutch, some would have not done it to a car they were just about to give up. I understand that is part of the agreement, but others may not have stepped up like that.
Kudos Brendan!
Old 01-13-2011, 10:09 PM
Jadz928
Jadz928's Avatar
plus 1, Robot
Lets get Leeroy over to the east coast.
Oh Carl? Carl Leguia.... paging Ispeed.
Old 01-13-2011, 10:19 PM
soupcan
soupcan's Avatar
Send it to the same place all the other Old Bastards go for the winter, SW Florida!
Old 01-13-2011, 10:33 PM
928mac
928mac's Avatar
Wow Mark, this is very cool.
I assume that this was your car that was donated to the community.
I have never seen this type of heart in such a internet community before.
The 928 really is a passion that seems to bring the best out in people.
I feel very fortunate to have found my 928, rennlist and the 928 owners club and all the affiliates.
As much as owning a ob 5 speed for a year would be a joy I don't feel I could give Leeroy the time required as there is still so much to do to my 89 S4.
I Hope someone who can show him some time gets him.
Brad
Old 01-13-2011, 11:03 PM
jpNcos
jpNcos's Avatar
Search Leeroy.
It's a good story about great people.
Old 01-13-2011, 11:23 PM
928 at last
928 at last's Avatar
Default Yes!
Originally Posted by jpNcos
Search Leeroy.
Kinda even gets me all warm and fuzzy........
Just speaks to the quality of the community and the somewhat disturbing fascination we all have with these cars.
Old 01-14-2011, 12:13 AM
James Bailey
James Bailey's Avatar
Mark's role is more like that of John Berford Tipton Jr's yoeman Michael Anthony.....
Old 01-14-2011, 12:28 AM
AO
Supercharged
AO's Avatar
I'd love to be the next steward... but my wife wouldn't. maybe next year.
Old 01-14-2011, 12:32 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,719 Likes on 1,319 Posts
Dude, that show ended in 1960, c'mon. The real Michael Anthony is in Van Halen.
Old 01-14-2011, 02:32 PM
BC
BC's Avatar
Just to review for those looking on:
I have been GRATEFUL to have the car, and have replaced:
Passenger side upper ball joint (Kit of other side is on passenger seat - ready for anyone to do it
Shocks (bilsteins)
Springs (GT springs)
Rack Bushings (solid)
Flushed Brake Fluid (ATE Yellow)
Front Brakes pads and rotors (bendix I think, and Good used rotors from a great guy)
Front Wheel Bearings (May need re-adjustment
Battery
Alternator (twice) (now has a properly wired AC Delco and new belt)
Power Steering Pump (from 928intl)
Transmission Oil (Redline)
Breather system
AFM (was surging and stalling - one trace was bad on original)
Gear shift lever (short shifter)
Gear Shift Boot (black leather)
Pinned the front bearing on the Torque Tube (see below)
Adjusted Clutch several times
Slave Cylinder
Clutch Master Innards
Front Bumper was repainted and matched to the cashmier beige
Front Driver's lights were replaced
A real alignment was done.
The Vac inducer was removed from under the spider - it was causing large idle fluctuations on downhill off-throttle coasting.
The muffler fell off on the highway early in the year. I went back to get it but it was not usable. So I had a pipe welded on to the end of where the break was. Sounds great, lighter, - perfect.
The car will probably need or you will want to replace:
1) Tires - man hole covers have all different sorts of tires
2) Torque Tube - This is going to be, in my opinion, a much needed replacement. The bearing for the front of the TT is pinned with a small bolt so it does not migrate forward. Its making some noise now when cold.
3) Tie Rod ends possible
4) Carpets (I may do this - minor issue)
5) Rear hatch cup - the hatch opens over large bumps
6) Cam box gaskets - Driver's side
7) Pan Gasket
8) AC seals - I believe at the expansion valve
9) Driver's seat bolster repair
10) Caliper Seals
11) The windshield needs to be re-installed with new goo. I made a temporary fix during the rainstorms here in Socal, but its a kludge and involves black tape.
Old 01-14-2011, 03:16 PM
Rick Carter
Rick Carter's Avatar
FWIW I also recommend Hacker.
Old 01-14-2011, 04:15 PM
SteveG
SteveG's Avatar
[QUOTE=BC;8212063]Just to review for those looking on:
Could be a wild ride.
Old 01-14-2011, 04:38 PM
BC
BC's Avatar
[QUOTE=SteveG;8212349]
LOL. The KIT for replacing the ball joint on the driver's side is on the seat for anyone to plan for doing. The driver's side was tight when tested in about july. I had to replace the passenger side as it was looser.
Quick Reply: Who wants to be the next caretaker of Leeroy
