does a high revving engine always burn way more oil
very cool thanks for the info all. This whole quesiton in this thread really has to do with me finding out alot of the owners of stroker engines have oil consumption issues. and I wondered if there was something inherently wrong with design or build. or is the design of the porsche 928 engine have an inherent design flaw as the high revving engines don't necessarily consume oil unless pushed hard....
maybe that is it , we have stroked motors and push them more for the fun of it and therefore consume more oil just due to what all have pointed out.
thanks to all!!
thanks to all!!
Former Sponsor
As a general rule a higher revving engine will use more oil, more power strokes, so more oil usage. However control of the oiling can stop it getting out of control, for reference a F1 engine will use around 1.5 litres in race of 300 kms distance. That's about as high revving as they get.
Greg
Greg
I guess you mean sucking past the guides when you lift off the gas, (ie more neg intake pressure), while getting on the gas causes more neg combusiton chamber pressure on all up strokes....do I have it close.
if so has anyone designed 4 or 5 ringed pistons or would that just cause more friction and be counterproductive?
thanks for everyones input.
andy
andy
High oil usage on the 928 is down to type or grade of oil and lack of a proper lubrication system, my guess is when I get my dry sump done, that has 5 suction stages, oil usage will be minimal. You get to use much lighter ring tensions when you have a well setup dry sump system, again indication how well they can control oil.
Greg
Smog legal street engines MUST feed the blowby back into the intake which means under deceleration the engine sucks has vacuum to the crankcase. Stroker engines due to the block dimensions use short pistons and less than ideal connecting rod lengths. This causes more rocking of the piston from side to side. Also stroker cranks have a bigger radius on the crankshaft which hits the oil more whipping it up to be ingested by the intake.
So the higher the rev's the more aerosolization , therefore more available to not only get past the rings but also get sucked into the intake,
thats why the scraper systems seem to help cut down on oil consumption esp on high revving engines.
Sorry to all, I am not a quick study it seems....!!!!!!
andy goetting
andy goetting
Pretty much how it is. Think about how roadracing stresses the engine. High RPM followed by hard braking, hard cornering, downshifts with engine braking (vacuum) and there is an oil storm going on in the crankcase....which is why race engines are drysumped even the NASCAR engines
I dont seem to have this issue with the new stroker, almost 3 seasons of racing now under its belt, and my previous stroker. it does go through near 1 quart a weekend of racing. in fact, i ran with anderson during those (2) 50 min pro races at laguna and only used a quart. street driving, havent seen much oil use at all, but im changing out the oil after 3-4 weekends and only drive it a little on the weekends, so im not a good test case for street oil use. however i do have friends with GTS's that use 1 quart every 500 miles or so, and I dont have that issue.
all my breather lines are alll stock. nothing modified on the engine, but the stroker and larger (too large) injectors.
Administrator - "Tyson"
First we should define "high revving" since 7k RPM would be high.....for a diesel engine.
My fathers 8,500 RPM 3.5 liter V8 is very easy on the oil usage. He checks it often and almost never adds any. Granted it's a factory dry sump.
and our motors , especially strokers, really dont make power in the high RPM anyway, unless it is a really tuned set up like Anderson/Fans with the CF intake. it pays to shift at 7000, but then its really not a HUGE advantage.. my motor only needs 6500rpm max RPM and the gains are slight over 6200rpm, and Ive been shifting at 6500rpm with no issues for years with no issues.
It would be cool to video you and your driving in the cabin with rpm, mph etc to see your technique so we could learn what you do that makes your style easy on the drive train.
andy
andy
