928 Forum 1978-1995
Sponsored by: 928 Specialists
does a high revving engine always burn way more oil
Old 01-09-2011, 04:47 PM
andy-gts
andy-gts's Avatar
Default does a high revving engine always burn way more oil
well just like the title.....does a high revving engine always burn alot of oil.
does drysumping change oil burning issues or is it strickly rings against cylinder walls that is the issue.?
or does anyone have a link
Old 01-09-2011, 04:57 PM
IcemanG17
IcemanG17's Avatar
good question......my "guess" is yes... I wonder how much oil NASCAR or F1 burn..since I never see them add any during pit stops?
Old 01-09-2011, 05:12 PM
andy-gts
andy-gts's Avatar
it seems alot of racing oils are very heavy weight. does that protect somewhat from the inevitabel oil getting past the rings at very high revs.??
Old 01-09-2011, 05:34 PM
andy-gts
andy-gts's Avatar
or is it just a fuel dilution issue needing higher wt oils?
Old 01-09-2011, 05:42 PM
Brett928S2
Brett928S2's Avatar
Hi
Difficult question to answer...but in my opinion yes....
When I do my high speed (and revs) runs at well over 6000 revs I usually use around 1 to 1.5 ltrs for less than 10 miles road mileage...lol
BUT...my engine "uses" a fair amount of oil anyway.... but I KNOW it uses a lot more at between 6000 and 8000 revs...
All the best Brett
Old 01-09-2011, 05:46 PM
mark kibort
mark kibort's Avatar
load dependant too
Old 01-09-2011, 06:08 PM
IcemanG17
IcemanG17's Avatar
I recall a 928 engine builder telling me that when he drove his 928 GTS and kept it under 6000rpm it didn't burn nearly any oil....above 6000rpm the consumption went way up
Another concept is when Devek was designing all their strokers and high HP stuff they always tried to make peak power at 6000rpm not more.....there must be a reason?
Old 01-09-2011, 08:04 PM
Daniel Dudley
Daniel Dudley's Avatar
Most 928s eat oil more than they run it past the rings. I guess some GTSs may be the exception.
Dave Roberts has a nice set up to update the oil breather.
Old 01-09-2011, 09:43 PM
andy-gts
andy-gts's Avatar
great info, thanks all!!!
are rings, or lands , or machining diff on 10k revving engines machined to higher tolerances
Old 01-10-2011, 07:28 AM
Cheburator
Cheburator's Avatar
I am not sure - my BMW Z4M revs to 8000rpm and it needs to rev all the time since it makes 343Bhp peak power at 7900rpm and does not use oil between services. My brother's supercharged BMW Z3M Coupe revs to 7750rpm and it makes 510bhp at 7500rpm and still does not use oil between services.
My race dry-sumped GTS engine did not use oil and it constantly revved to 6750rpm...
Old 01-10-2011, 08:24 AM
slate blue
slate blue's Avatar
As a general rule a higher revving engine will use more oil, more power strokes, so more oil usage. However control of the oiling can stop it getting out of control, for reference a F1 engine will use around 1.5 litres in race of 300 kms distance. That's about as high revving as they get.
Greg
Old 01-10-2011, 01:06 PM
RKD in OKC
RKD in OKC's Avatar
Is it the high revs or lifting off the throttle at high revs?
Old 01-10-2011, 02:36 PM
Brett928S2
Brett928S2's Avatar
Hi
On mine its both...under hard acceleration while on Nitrous at high revs it smokes and lifting off it also smokes....
All the best Brett
Old 01-10-2011, 08:57 PM
andy-gts
andy-gts's Avatar
I guess you mean sucking past the guides when you lift off the gas, (ie more neg intake pressure), while getting on the gas causes more neg combusiton chamber pressure on all up strokes....do I have it close.
if so has anyone designed 4 or 5 ringed pistons or would that just cause more friction and be counterproductive?
thanks for everyones input.
andy
Old 01-10-2011, 10:01 PM
Brett928S2
Brett928S2's Avatar
andy
Hi Andy
Dont forget my engine has HUGE pressures due to the Nitrous... for example, on my last high speed runs it blew both rear cam cover gaskets (the cork ones) ...not quite sure why...they were changed around 4 years ago but maybe they were on there last legs and the excess pressure took the line of least resistance....
Regarding the 4 or 5 ring piston, although there were pistons with 4 or 5 rings in the old days they were usually on slow revving engines like diesels.....also dont forget there is only so much room on a piston for rings and there must be some solid piston between each ring or they wont work at all...so size is important....old diesels (big pistons) high performance high revving engines (small pistons) comparatively...lol
All the best Brett
Quick Reply: does a high revving engine always burn way more oil
