Panamera Wheels
Front Tires are 245/50/YR18
Rear Tires are 275/45/YR18
Will these fit my 1988 S4 without rolling my fenders?
The above tires come on take off wheels from panamera.
Thomas
Thomas
245/50-18, unless that is a typo, those tires will have a too large diameter and will rub in the wheel well when you turn sharp. I had this happen with 245/40-18's in the front.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
So what you are saying is I can use the wheels. But I will have to purchase shorter tires. The wheels are not the ebay ones as pictured above. The wheels I am looking at are off a panamera with many more spokes.
Thomas
Thomas
Even if they fit it will throw your speedo way off. I think the rears we normally put on our 928's that are 18" diameter are 35 series side walls...quite a short sidewall.
Supercharged
18x8 et59 front Porsche Panamera 10-spoke silver
18x9 et53 rear Porsche Panamera 10-spoke silver
Wheels will fit fine. But as others mention (which I failed to notice), the tires are wrong. 235/40r18 tirew for the front, and 275/30(or35)r18 for the rear would work fine.
I've got a set of ten-spoke Panamera wheels in the rafters awaiting spring with just those measurements and stock tires. I plan to try it out but expect to remove the tires and go with shorter sidewalls like Andrew describes.
My Panamera wheels
My Panamera wheels
I wish I could find the wheels for $700. My guy wants 1300.00 with the tires. I am going to try without the tires for 750.00
I also think they will look awesome on my white 928
Thomas
Thomas
Looks like the are:
The weight is about 50-50 front/rear, putting too much tire in the rear just aggravates understeer. And 265's will fit the 9" rims a bit better than 275's. But that's just my $0.02
