Doors locked with keys in it.
Spare is in the console as I just got home from sears having it aligned.
I have pictures from last key I had made so will have to send for another key to be made. Any easy way in?
The three not-so-easy methods that I know of are:
1) the magic "?" tool, I am skeptical of that with later cars because there is a metal shield in there, protecting the lock from such things... Worth a try, however.
2) The removable panels in the floor, behind the seats. This only works if one of the seats isn't all the way back, and if you have extraordinarily long/skinny arms.
3) Remove the pass-side quarter window, as Rog describes in this post. This is the only method that I know for sure works, having seen it done at the recent Third Coast gathering. The trim was removed (which is a bitch to get back in), and part of the seal was cut to get it started.
(Edit: Cutting the seal may not be necessary??)
Good luck, and keep us posted!
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
475hp/460lb.ftA wedge and two airbags...you can get a frame open about 4" and wont hurt nothin. Lots of spring across 4-5' of door frame from the hinges to the upper edge.
You can pull glass out a couple inches as well, if you have to.
First time it has auto locked since I have had it. Any idea why? I had both keys as I was just at sears for alignment. Was going to leave car with them till after they close. Told them to lock keys in it as I had the extra. Found I had a bad inner tie rod. Called Roger to see if I could run by and get one and headed home. Put key in console. Pulled in garage, ran in and realized I left my phone in my the car. Went back out to get it, lifted handle and I heardthe locks cycle and both doors are locked.
Roger and Sean, now you know why I did not return you call or text. Sorry aint got no phone.
Anyone tried a socket on the door **** to check the size? Im not a very big guy, cant for the world of me see how someone gets their arm up in there far enough to reach it with channel locks. May have my wife give that a try when she gets home.
If not, locksmith or back glass is coming out.
Question: My buddy and I just became 928 owners. His ignition key is the red one - m/y 1985. My ignition key is the longer black one - m/y 1981. Which is correct? Also, can you get a spare made at a Porsche dealer or ?
I'm thinking it is the black longer one.
Thanks,
Mark
Last edited by SanDiego928; Dec 23, 2010 at 09:11 PM. Reason: Hijack was not intended - I forgot
Biggest socket I had was a 32 as well and as you say, no go, however I just pot a calipers/vernier on it and the outside diameter is coming out at, 34.1mm/1.34inch..
Hope this helps,
Mark.
