Overload protection Switch tranny leak issue
Looks like there is a crush type washer on the overload protection switch. Mine is leaking.
My question is can I snug it a bit and see if that helps or should I replace the crush washer. My concern is over torque and causing any further issues.
I also have a small pan gasket leak and will be getting parts from Roger to address that also. Figured while it is apart and replacing pan gasket, filter, etc. will take care of both.
Anything special I need to know before tackling this?
Jim Bailey was a big fan of running a straight edge over the pan rails while you have it off the tranny. Use a hammer to make sure the pan bolt holes are flat. Good advice.
Ensure that you buy the updated pan gasket as Mercedes Benz modified the gasket. The last number in the part number for the old gasket is "10" and the modified pan gasket is "11".
It is imperative that you do not overtighten the pan bolts.
Tails 1990 928S4 Auto
Jerome
Leaking tranny 88 s4 Overload Protection Switch
the original post on this thread was from my PO. The OPS is still leaking. Changed the o-ring #33 in below diagram. The post mentions a crush washer, but didn't see one involved. The pan gasket is still an issue and wondering if a new pan needs to be installed. Have changed the gasket but leak remains.
Open to ideas. While it may sound cheesy, is some good old fashion plumbers tape around the OPS an option to stop the leak?
Chronic Tool Dropper
A new pan isn't expensive, and IMHO it's cheaper than ttwo tries with the hammer and straightedge trying to get a deformed one to seal. Most Critical that you use your best technique to get the bolts drawn up evenly, and use a good inch-pound torque wrench on the bolts. The sump bolts take a lot less torque than the two drain plugs, yet folks continue to twist on them while trying to solve a leak.
I put a smear of Teflon thread sealing past on the plug threads on those two drains.
The seal for the reservoir can be iffy. A spray of lubricant on the pan nozzle and the threaded part of te hreservoir fitting may help.
The brass inserts molded into the bottom of the reservoir have no tolerance for any thing more than 'just barely snug'. You want to keep it from falling off, no more.
Others will need to chime in on how to seal that overload switch.
Under the Lift
Under that switch is the B1 thrust valve and it has 2 o-rings. I'd pull that and replace its 2 o-rings. Also, the switch is torqued to 52 ft-lbs. I don't think Teflon tape will help as the threads are not sealing component.
There's always the real possibility that the switch itself is passing fluid internally. If all the attempts at external sealing don't succeed, another switch might be the solution.
Paul,
Isn't the crush washer in the diagram you posted above, number 33?
Looks like we get some more practice installing that B1 thrust valve, what fun! Maybe if we replace your pan, we do the B1 work while the pan is off, and guide that plunger into it's hole from inside the tranny?
If memory serves, part #33 from the diagram is an o-ring, not a crush washer. I don't think you can see the B1 band from below unless you remove the valve body and lower plate after dropping the pan. The pin on the B1 thrust valve is fairly well captured so you shouldn't have too much problem getting it in correctly.
Mike
Mike
