WYIT jobs during odo gear R&R?
I am finally getting ready to replace my odometer gear that gave up the ghost a few months back. What do I need to do while I am in there?
All of my lights appear to be working well, but if it is best to replace some bulbs while I am in there I figured I would. Should I replace them all? If so, are they fairly cheap, and can I just get them from Radio Shack or Auto Zone, or do I need to give Roger at 928sRus a call??
Anything else that needs to be done while I have the pod apart??
Agreed.
Bulbs or LEDs. The bulbs are not off-the-shelf at your typical store. Also be aware that you can get just bulbs or bulbs in holders.
You could also tweak the voltmeter pot to get a good voltage reading.
How do you tweak the voltmeter?? I don't know if mine is off or not...it seems fairly accurate, but... I know that my speedo is pretty good. It is off by about 1 mph from my GPS. My pod is crack free so I guess it is just the bulbs and maybe a little volt tweaking.
Is you gas gauge accurate? Mine is off by a qtr tank, and I always assumed it was the sender, but tested the sender last weekend, and it looks like I will be pulling the pod again to adjust the gauge.
You'll find a little adjustment potentiometer on the volt meter. Connect up the instrument cluster without any pod and then adjust the meter to match the reading from a good voltmeter. Start the car to check to calibrate it at that point. This would be most effective after cleaning the grounds.
I'm very happy with the background lighting LED's I got from Nicole. I changed all the bulbs and did the painful soldering in of X-mission bulbs. Now that my odo failed, I get to go back in again but it gets easier each time.
