928 Forum 1978-1995
Sponsored by: 928 Specialists
Eibach Spring Fitting
Old 11-16-2010, 01:30 AM
Podguy
Podguy's Avatar
Default Eibach Spring Fitting
Based on 928 International's web site their Eibach springs fit from 86.5 to 95. IS there any reason they will not fit on the older cars as well?
Thanks for the input.
Old 11-16-2010, 01:33 AM
Erik N
Been selling Twinkies on Ebay,
have some extra cash right now.
Erik N's Avatar
DAN HOW THE HELL ARE YOU! TEX
Old 11-16-2010, 01:41 AM
GlenL
GlenL's Avatar
It's something about spring perch sizes.
Old 11-16-2010, 10:02 AM
Mike LaBranche
Mike LaBranche's Avatar
Sure, they fit the early cars, but you'll probably need the later, smaller spring perches. Everything else is pretty much the same.
Old 11-16-2010, 02:12 PM
Optimator
Optimator's Avatar
In addition to the 85 and later small diameter rear perches, I beleive you also need ride height adjusters on all four corners. Early cars have fixed lower perches in the front that are mounted about 1.5" lower on the shock body, in order to accommodate longer springs. Using S4 springs or shorter with the early shocks would make the front way too low.
Old 11-16-2010, 02:52 PM
karl ruiter
karl ruiter's Avatar
You need to change the spring perches. Let me know if you need a set. I got Eibach's for my '79 and my '88 and got the updated spring perches for the '79. However, before I installed the springs I updated my shocks and the new shocks came with all the perches and hardware and such. Upshot is I have a spare set up late perches. 928 intl has them for not too much $ also.
Quick Reply: Eibach Spring Fitting
