Hit While getting gas...
#46
Just picked it up on Friday. All's well, just called the insurance, his ins. paid 100%.
Oh yea, Pfaff in Newmarket, A1 job and the folks there are good people aswell, really took care of me well.
#47
Under the Lift
Looks good!
How was the repair done? Standard would be pound/pull out, some filler, paint whole fender.
I have a similar dent, but self-inflicted. Deeper, but paint intact. Paintless dent guy gave up after failing to even budge it with his tools, noting that tempered aluminum is almost impossible to work out. I went to Home Depot and got a stronger tool (1" pipe and rubber caps). Worked the dent out myself about 98%. Ripples are noticeable in sunlight. Reputable body shop wanted $500 to finish, but was going to spray 2-stage paint on the whole fender. My original paint is single stage. Bought a matching, nice, used fender from 928 intl.
#50
They heated it and rolled it out. the paint process did not include the top of the fender. they sprayed the side with a blend. I can see the difference but unless you knew about the damage(witch was minor) you would never see it. the Clear coat makes it look newer on the fender area.....
Looks good!
I have a similar dent, but self-inflicted. Deeper, but paint intact. Paintless dent guy gave up after fialing to even budge it with his tools, noting that tempered aluminum is almost impossible to work out. I went to Home Depot and got a stronger tool (1" pipe and rubber caps). Worked the dent out myself about 98%. Ripples are noticeable in sunlight. Reputable body shop wanted $500 to finish, but was going to spray 2-stage paint on the whole fender. Original paint is single stage. Bought a matching, nice used fender from 928 intl.
#53
Under the Lift
#54
