928 Forum 1978-1995
Sponsored by: 928 Specialists
Mounting to a engine rack... Bolts??
Old Nov 1, 2010 | 11:26 AM
RPetty's Avatar
RPetty
Default Mounting to a engine rack... Bolts??
Does anyone know the bolt size, pattern, pitch or whatever is needed to mount a short block on a rack?
All I know is it's a 5.0
Don't really want to haul it around trying to find the size.
Old Nov 1, 2010 | 11:28 AM
GlenL's Avatar
GlenL
12mm x 1.5mm pitch
Use the bell housing bolts to match against.
This is neither fine nor coarse. I use bolts from the suspension that I harvested off a parts car.
Good luck.
Old Nov 1, 2010 | 11:31 AM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Yup.
Also have a look at your engine stand first, if the standoffs are longer, a front lower control arm bolt (M12 x 1.5 x 100mm) won't work.
https://rennlist.com/forums/928-foru...do-i-need.html
https://rennlist.com/forums/928-foru...ine-stand.html
Old Nov 1, 2010 | 11:44 AM
fraggle's Avatar
fraggle
I got a set from a local fastener place. Had to special order, but it was cheap enough.
Old Nov 1, 2010 | 11:50 AM
RPetty's Avatar
RPetty
Thanks guys!
Old Nov 2, 2010 | 04:42 PM
86'928S MeteorGrey's Avatar
86'928S MeteorGrey
Ace Hardware carries the correct pitch. I had to use washers to get mine setup correctly. I'll take some photos when I get home...
