New front ball shift cup replacement or short shifter upgrade?
Been selling Twinkies on Ebay,
have some extra cash right now.
Try a different oil for the notchiness. Redline 75/90 NS made a difference for me.
https://rennlist.com/forums/928-foru...sp-tranny.html
Having said that I don't think its gearbox wear that is the problem. I can still shift with a couple of fingers and shifting isn't difficult. I've also tried shifting several well cared for 928's and they all feel about the same with the short shifter installed.
Afshin,
With something like a manual transmission in the 928, you really do want a positive and direct feel imho.
This shows positive engagement, and strength.
Basic Sponsor
Red Line Manual Transmission Fluid 75W 90 NS GL-5
Been selling a lot if this lately. $11.75 a quart.
After driving two cars with the "Lizard Shifter" long enough to get used to the shift it was awesome.
Exactly how the car should have been from the factory. Felt notchy to strat with but once you know where to aim the shift it became smoother.
Definitly an improvement on the worst gearbox known to mankind.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Ah yea right ...."Definitly an improvement on the worst gearbox known to mankind. " even a bad 5 speed is so much better than the best automatic
You just need to learn how to best operate three pedals with two feet while driving with one hand and shifting with the other!
While I was sorting out some issues with my clutch I looked up and it appears the the front shift ball cup bushing is gone!
I have the stock long shift lever. Question is do I go through what looks to be a PITA to pull down the heat shield and replace the bushing or just go ahead and install a short shifter from Roger that appears to disconnect and not use the front shift linkage?
Thanks.
Thanks.
Redline 75W-90NS is excellent stuff. It cured quite a bit of heat-induced crunching on the race car. We still need a trans cooler, but the improvement was huge over standard Mobil-1 and Mobilube SHC.
I have not shifted Roger's kit, but what I do know is that replaceing the factory front ball cup is a temporary fix that will last you another 40K miles or so and then you will have to do it again. And it will be just as miserable the next time. You can put in Carl's steel front cup, but I just did that with the motor out of the car and it was a miserable install that required me to buy special tools in the end. And that was with the motor out of the car. So, I think this, plus the glowing reports of the shifting performance really point towards Roger's kit.
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I have a short shifter in the GTS, does anyone notice that the shifter boot gets in the way when you shift down into 1st and 3rd? Because the **** is much lower, the extra leather tends to get bunched and pinched... any ideas short of getting a new "trimmed" shifter boot?
