928 Forum 1978-1995
Sponsored by: 928 Specialists
UK RECORD 208.10 MPH IN A 928
Old 08-15-2010, 08:13 PM
  #46
Brett928S2
Brett928S2's Avatar
Hi Rick
I "think" those figures are wrong as they do not take account of autobox drag losses....
I was actually expecting to have to run even higher revs at the time....
The revs and speed figures I gave are accurate ...the revs come from my Ecu and the speed from GPS...
I would think that any system must have a built in error, but not that much....
All the best Brett
Brett928S2 is offline
Old 08-15-2010, 08:14 PM
  #47
Lizard928
Lizard928's Avatar
I find it VERY disturbing that you will not tell us where this happened.
But maybe I am the only one who thinks your lack of willingness to disclose where it was done says that you were on public roads.
Lizard928 is offline
Old 08-15-2010, 08:15 PM
  #48
Brett928S2
Brett928S2's Avatar
Originally Posted by 89FrontPorsche
You need to do something to counteract the natural tendency of the shape of the car to produce lift. Bernoulli's prinicple is involved here and when air travels over the top of a wing, the air underneath flows in a straight line. The air over the top must travel faster to meet the air at the bottom and therefore creates a low-pressure area. This is why a wing works and why your car, or most any car with nice, flowing shape like the 928 has, needs something to push the car down onto the ground, which is why you felt it "go light" at higher speeds which also results in less traction, among other things.
An S4 spoiler would be helpful, even going so far as to put some additional negative pitch to it. That means putting some angular shims between the wing and the car. Through-drill them so you can experiment.
The downside is that there has to be a compromise between downforce and aerodynamic drag. Too much wing angle and it robs the car of the ability to go faster. You probably already know this.
Additionally, the rear isn't the only thing to worry about. The front of the car is lifting up too and affecting steering. The speeds you were traveling at are higher than what it takes to get a multi-ton airliner off the ground. Most airliners rotate the nose high at around 150 knots which is about 172 mph. There is no doubt your car is creating lift but the spoilers are having some effect. I would not go much faster than 150 mph in a spoiler-less 928. Those Porsche engineers knew what they were doing. The spoilers on your car are designed to be "satisfactory" to the factory design speed limits of the car.
Naturally you are exceeding those with the nitrous and thus, entering into race-car territory.
A more aggressive front spoiler to generate front-end downforce is needed as well as more downward "lift" at the rear. But the more downforce, the more aerodynamic drag at high speeds so it's an art as much as a science. But in clinical terms, it's called "induced drag" or drag due to lift.
Some people, and myself included, have taken model cars, put them in a homemade wind tunnel and experimented with the model on a kitchen scale to see how much downforce I could make. Those scales are available at cooking shops and are usually not too expensive.
Then, to make it even more interesting, I had gone so far as to put two scales side-by-side to see what happened front vs. rear.
It was all an academic exercise while attending an aeronautical college years ago. I got a "B". Was really angry for all the effort I had expended. Internet didn't exist yet and all my data was actual, calculated and charted.
The drag part of it is a little harder. You have to take a string and put the car on its wheels and I found they needed bearings...so it started getting involved but..with the air moving at a constant rate, I could use the string, run through small pullies and attached to the scale, would pull it down a certain amount.
Naturally, the larger and more aggressive spoilers I tried, the more drag.
It's not something everyone enjoys doing but since it was an exercise for a paper, I thought it all very enlightening.
You have entered into the world of aerodynamics, sir. Not the goofy, kid-racer with funky colors on the cars with fart exhausts type of wings, either. Serious stuff. Many F-1 racers typically blast down the straights at 2225 mph+ often limited by either the length of the straightaway or by regulation. But aerodynamics plays a HUGE part in it.
http://en.wikipedia.org/wiki/Formula_One_car
Be careful, m'lad. You are in dangerous territory. I wish you well and success. But do so in one-piece, please.
Hi
That was an extremely interesting read
I would never have thought about trying out spoilers etc on scale models....
Thanks for the thoughts.
All the best Brett
Old 08-15-2010, 08:20 PM
  #49
Brett928S2
Brett928S2's Avatar
Hi
Speed itself is not dangerous, whether on a public road or not..... some public roads are totally clear of traffic and if so then the only danger is to the driver....
German Autobahns are perfectly safe to run at over 200 mph as an example....as long as they are clear.....
You cannot think I would be silly enough to do this on a public road when others were driving on it.... our roads in the UK would make that practically impossible....
All the best Brett
Old 08-15-2010, 08:31 PM
  #50
928mac
928mac's Avatar
Congrats, very cool achievement
Due to the threads on different power adders. Why NOS rather then a SC or Turbo
928mac is offline
Old 08-15-2010, 08:42 PM
  #51
Brett928S2
Brett928S2's Avatar
Hi
Two reasons actually...
1, I used to be a Top Fuel crew chief so worked for years with blowers and wanted to try something different....
2, I thought NOS would be a LOT cheaper than a blower, and when I started at low levels I was correct.... on an average 928 a kit for say an EXTRA 100 to 150 hp would cost under $1000...
Because I increased the hp I needed and was a friend of Trevor Langfield (owner of Wizards of NOS) I started getting all the latest experimental Nitrous stuff....
My current system is the first road car in the world with his new REVO system on it but it was NOT cheap lol....
But it is light years ahead of anything anywhere else in the world in Nitrous systems...
All the best Brett
  #52
928mac
928mac's Avatar
Originally Posted by Brett928S2
Hi Rick
All the best Brett
The error is in tire slippage.
As the car gets light, and because the road is not perfectly level, as the car lifts up and the weight comes off the rear tires there actually loose traction and you get wheel spin.
So your tires are doing 210 or more and you are doing 208 or whatever depending on slippage.
928mac is offline
Old 08-15-2010, 08:45 PM
  #53
Nicole
Cottage Industry Sponsor
Nicole's Avatar
That's pretty darn fast! Congratulations!
I'm glad that man and machine survived it unharmed.
Nicole is offline
Old 08-15-2010, 08:47 PM
  #54
Brett928S2
Brett928S2's Avatar
Hi
Wow I never even thought of that...
As the speed came from GPS I imagine thats the accurate one out of the two....hmmm my data logger has an input for a "wheel speed" sensor...which I do not have.
But going on what you said it would give a different (maybe higher) wheel speed than road speed.
All the best Brett
Old 08-15-2010, 08:49 PM
  #55
Brett928S2
Brett928S2's Avatar
Hi Nicole
There were a few seconds when I lifted off that I wasn't very sure I would survive lol
I do not consider it very fast when so many American 928s have exceeded my speed though.
All the best Brett
Old 08-15-2010, 11:39 PM
  #56
Iwanna928
Iwanna928's Avatar
Awesome run andthank God you are safe!
Amazing effort on your part!
Now get a roll cage and work on the aero dept!
Iwanna928 is offline
Old 08-15-2010, 11:49 PM
  #57
michael j wright
michael j wright's Avatar
Congrats on the fantastic run! Have been waiting to hear how all turned out! Can we now see pics of the final set up. Last ones i saw were right before your last mod.
michael j wright is offline
Old 08-16-2010, 12:01 AM
  #58
Imo000
Captain Obvious
Super User
Imo000's Avatar
WELL DONE!
The error is in tire slippage.As the car gets light, and because the road is not perfectly level, as the car lifts up and the weight comes off the rear tires there actually loose traction and you get wheel spin.
I have hard time beleving this. If the tires loose traction, the RPMS will shoot up, followed by tire smoke. They car would become extremly twitchy too.
Imo000 is offline
Old 08-16-2010, 12:06 AM
  #59
NoVector
NoVector's Avatar
Superman has pajamas that say "Brett928S2" on them. Congratulations! Would love to see pictures of your engine/NOS setup when you get a chance.
NoVector is offline
Old 08-16-2010, 12:29 AM
  #60
jorj7
jorj7's Avatar
Originally Posted by Imo000
WELL DONE!
Longitudinal tire slippage is real and is a factor in top speed.
jorj7 is offline
Quick Reply: UK RECORD 208.10 MPH IN A 928
