Block damage What would you do?"
#31
Basic Sponsor
The block and girdle from Richard's engine were sold.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#32
Almost Deleted
Sterling, I agree it would be difficult to keep the shavings out of the lower end. However, if we could... my thought is a larger piece of aluminum JB welded in place would function as a better patch than simply patching with JB Weld [or devcon].
Thoughts?
#33
depending on the tolerance grouping on the 2 blocks why don't we just switch blocks? Take John's piston's, rods and crank, put new rings and main & rod bearings and he has a good motor.... We would have to grind off the posts in the V that hold the earlier throttle body in place but that is easy to do...
I think Brad W's suggestion is a good one and certainly worth a try. By fitting a piece of matching aluminum you would minimize the amount of "goop" required and any attendant problems with different expansion coefficients, etc.
The damage on the pass-side from the A/C bracket looks like it has a perfect plug already-- remove the A/C bracket, finish breaking out the chunk if it is not already loose, clean it thoroughly and bond it back in place. The rough edges from the original break are perfect to help lock it in place.
For the other one, on the alternator side, cut up a scrap girdle as suggested, and grind that and the block to add some groves or other keying features to help hold it in place.
Keeping the engine clean should be no problem-- clean the pan-pasket surface and inside lower-edge of the girdle and then use plastic and duct take to seal up the bottom of the engine, working around the two broken areas. The only exposed part of the girdle interior would be right around the broken pits. And then use a shop-vac (not compressed air) to suck up the swarf.
There's lots of other options, but that's what I would do.
#34
Thanks everyone for your comments so far.
Hilton, indeed, I'm the super nerd with the Irix background. I would really hate to part this one out. Outside of the block being hosed into oblivion, the car is in darn good shape.
So far, I'm probably leaning toward the Devcon/patch fix or the welding route. I just bought the car a few weeks ago, so my wife would kill me if I dropped another $3k+ on a new donor motor. Calling a local welder to at least give an assessment is free or really cheap. There is a fairly large commercial airport 15 miles down the road, so there has to be some good aircraft certified welders near.
I'm always open to other suggestions, so please keep the comments coming.
Go with more JB Weld but remove as much of the old JB Weld so you can do it all fresh.
If not: http://meadville.craigslist.org/pts/1812413481.html
Good luck!!!!
Michael
#36
There is some thing I don't understand. It seems That Porsche can deliver a block with pistons without the crank case. But, they don't sale the crank case lonely.
So I suppose that it is possible to take the crank case from a failed block and put it on the block from that "girl". Why should not that really a solution?
Stephane
Stephane
#37
Almost Deleted
Stephane
Stephane
#39
Former Sponsor
I've fixed a bunch of these, over the years. The lower cradle is a different material that the upper block and they wled pretty nice, when they are perfectly clean. I would not attempt to weld that, in the car.
I have fixed them while still attached to the upper block, but only when they have a little bit of damage...this one is really bad.
Pretty easy to remove the engine, put the engine on a stand, turn it over, and remove the cradle. Clean the crap out of it and bolt it onto another block. to keep it from warping. Pre-heat the area and weld in little amount, at a time, to contol how much heat goes into the cradle. When you are done welding, put it on a mill and surface the pan area, rethread any pan holes tha need it.
Re-install it and it will be good forever.
#40
#41
Unsolicited $0.02
Whether you weld or bond (JB Weld), the pieces need to be REALLY clean, like all oil leached from the casting clean. This is where the citrus cleaners and good detergents work better than petro solvents.
As far as welding goes, I have welded on these girdles as well as bonded fittings on. The cast aluminum welds easily as long as good prep was performed... 'ya gotta get all the oil out of the casting !
For this type of repair, I would sure like to weld the piece as it spans a bolted / gasketed connection. However, to weld this piece effectively, I think the person welding would require more access than what can be had with the engine installed. As GB mentions, the required pre-heat could be a huge challenge if in the car.
All in all, my vote would be to repair the girdle loose, some how clamped down / bolted to a block while it's heated / cooled.
Again.. my $0.02
Again.. my $0.02
#42
I have not seen any discussion of whether the car runs well or if the damaged girdle - which only holds the crankshaft in place, after all
- is rigid enough for every day use. Clearly this engine is not a candidate for the track or ORR, but it may be perfectly adequate for a DD - it's not like it was overstressed when new or is breathing heavily at 135mph.
If it's strong enough I like the idea below ...
... except you wouldn't need to bolt on the whole pan, just a strong, flat piece from one side of the break to the other (bar stock?). That will give you a flat surface AND access to work the epoxy after it's in place to cure.
Not perfect, not elegant, but it might be fine for years.
Take lotso pix and keep a good log - b/c you don't want to be _that_ PO who didn't disclose. Do you? And the log and pix will mean your disclosure won't hit the price that badly.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
... I think it will be your best solution ... if you clean up the edges so that there is some area to put the epoxy ... and then bolt the sump up with no gasket. This will lock it into the correct position. When it cures unbolt the sump and add any extra reinforcing material that you think might be required. ...
#44
Almost Deleted
Fogey, the car ran well before we found the issues. It needed a throttle position sensor, knock sensors and a few other typical small things [all typically done with an upcoming intake refresh]. It started on the first key turn every time, held oil pressure just as normal and always stayed within the operating temperature ranges. All in all, its still a great car if we can get the girdle sorted out.
We'll definitely take lots of pics throughout the process of fixing things. My original plan for this car was not a flip or a show-winning concours piece... but rather something that ran great and looked good. [and maybe a few performance mods such that I had a chance of keeping up with Jim M. at Third Coast
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
#45
My vote is for pulling the motor and either some pro welding or a new block. This lets you get at everything else on a stand where it is much easier.
I would have said it's a winter project, but you have no winter in Texas.
