My very special message to the PO
Oh, I don't think we're heading to OT. The thread is clearly inspired by some sort of technical malfeasance by the OP's PO. Many of us can relate...
So John, what discovery inspired this thread and the eternal damnation and all?
Hahah my thoughts exactly. My PO must have used a the discount electrical tape . What a gummy mess I removed from behind the center console, and my doorlocking, clock light, shift indicator lights still dont work consistently. Sad
Well, it starts this way:
I knew there was a short somewhere in the car. So I go through the fuses, pulling each one until the current leak goes away. I started from right to left on the fuse panel. I get to the first fuse that isn't an 8A fuse, and low and behold, as soon as I remove that fuse, the leak drops to zero. I look at the diagram, and the first fuse that isn't 8A is the fuel pump.
So I figure the first thing I'll do is try disconnecting the harness, see if that fixes anything. I discover that the female connector in the harness is broken, and I can't reassemble the wires. Ok, fine. So I order a new connector, which I'm waiting for. I figure while I'm waiting for that, I'll pull the panel and try and trace down the connection by hand, looking at the mass of squid ink linguine that is the back of the 928 fuse panel.
So I start to unbolt the panel, but I can't get a good look, so I start pulling the connections on the panel, so I can take it off the car. I'm having a tough time pulling the connections, so I try pulling a relay so I can get a better grab on the connector underneath. "Crack" goes the first relay. And "Crack" goes the second relay. So I've trashed two relays in the process.
Then I start pulling the connectors, which seemed superglued to the box. I get all the connectors off, and count from right to left, looking for the first non 8A fuse, so I can look on the other side. I have the chart right next to me. I count 12 from the right most fuse.
Inside lights.
That's supposed to be 8A, but it has a 25A fuse.
Effing inside lights.
I just spent two nights, wrecked two relays, had to order a female connector, and a lost a good portion of a sunday morning because the PO placed the wrong fuse on the car.
(Yes, I should have checked it myself, but I'd rather damn the PO instead )
Inside lights.
First thing I always do is pull the panel, replace all fuses, all 53 relays and clean all contacts.
You will be better off now.
I hope you saw the sliders and hooks that retain the 85 panel plugs.
Oh, and I am certainly looking forward to going under the center console. He told me "the stereo doesn't work". I'm certain it has nothing to do with reversing speaker polarity, whatever other electrical nightmares await me.
Ooooh... that's a good one!! I feel for you! I and my mech spent a lot of time trying to figure out why my windows worked without the key in the ignition (killing the battery when the sticky passenger window switch stuck in the UP position), only to find that two adjacent relays were reversed, so the window power never shut off.
Team Owner
first thing to do to a new car is pull the relays and the fuses and make sure they are all in the correct locations, also clean the battery and the hot post connections.
if you do this you may find everything works as it should,
dont forget that some relay and fuse positions are empty so don add parts to the CE panel
[I] would like to thank the two PO`s of my car for keeping all the records, original paperwork, tools, misc things, (like cargo cover) all keys, etc. AND... not letting anyone bugger up the electrics. Now all the screwing around with car is up to me !!! BEWARE next owner...buahhh !
