Oil Pressure indications
looking to draw on everyone's experience. two weeks ago my oil pressure when cold would go to 5 bar and once warmed would settle at 4.5 to 4.8 at speed and more than say 2k rpms. it would never go below say 2.5 bar. now couple weeks later and 400 miles logged the pressure still goes to 5 bar and then settles at 4.0 to 4.6 bar and at idle will go down to 2 bar. does this sound "normal" ? what is your pressures.
note: two weeks ago the OAT was about 65 to 70 deg and lately its been in the
90's. also for info, using M 1 15-50.. thanks
Supercharged
Sounds about normal. I find the M1 15-50 suffers a bit in very warm conditions, but never to the point where I get concerned (yet). As long as you don't get a low pressure warning I think you're fine, and that doesn't occur until oil pressure falls below about ~1psi.
yeah possibly the oil i'm using. did a search for what others are using and holy s..t
too many use this no don't use that post's for me. maybe try some torco 20-50 if i can find it here locally. if not have to order some
Archive Gatekeeper
Sounds good to me. 2 bars at idle when really hot is fine, IMO. After being stuck in traffic today in 100o heat I'm going to switch from 15W40 to 20W50 for the next oil change, as I was down in the 1-1.5 range. Too low for my comfort.
yep it's been hot lately Rob. with a new engine i worry bout everything. you, probably even more. Rob
what are you seeing for pressure at say 2500 to 3500? do you make all the way to 5 bar?
3rd its fine......M1 will suffer quite a bit under HOT conditions...and the gauges are not exactly precision either......they seem to have quite a bit of variation given equally well running 928's..... for example on my old 88 S4 that ran EXCELLENT...it would never go over about 4.7bar....max.....clearly it had more pressure than that....but thats just where the gauge stopped....
i was kinda kicking around the idea that maybe there is a buildup of "gunk" in the oil pressure sender. from the size of the sender i'm guessing that it is of a bellows type? anyone ever had one apart or tried cleaning
Dan
'91 928GT S/C 475hp/460lb.ft
