Brake help needed on race car
The Parts Whisperer
Chronic Tool Dropper
Mark--
Larger master cylinder = more effort but less pedal feel.
It may be worthwhile looking at how the pedal is attached and where the rod for the master cylinder attaches. Similar to what the Tilton and other adjustable balance bar systems use, you can adjust the linkage pivot positions to mimic the effects of a larger or smaller MC. Just make sure you get full retraction on the MC when the pedal is up, so the feed/bleed port to the reservoir is clear.
You may also consider a different pad.
awesome job Mark, as usual!
times??
anyway, I havent done much work on modifying the braking system, and still run whatever bias was in the 86 and now 87 and I cant notice a difference. (I probably can use a lot more and I think I might have more with the 87 chassis now.)
I dont think a smaller booster will do it, as it doesnt run out of capacity with short hard brake efforts. a smaller booster would run out of vacuum sooner if you pumped your brakes while killing your engine. Dr Bob, can you explain?
i think that bleeding off pressure could do the trick, but that might need to be tested first, as it might have to be a pretty large leak to really change the "feel". what do you think steve??
mk
times??
mk
The Parts Whisperer
Mark--
The Parts Whisperer
Jim if I remeber correctly when I ran without the storage tank it felt boosted at the beginning but lost vacuum as I depressed the pedal.
For a track only car I don't think you should even be discussing
standard master cylinders, brake servos and vacuum bleed valves.
I don't have a lot of 928 experience yet but for my Triumph Dolomite
period race car I threw out the stock vacuum servo, the tandem master
cylinder and the rear axle anti lock proportioning valve. I made up
a system without a servo but with dual master cylinders and
a brake balance bar operated by a push rod from the standard pedal.
With this set up I could adjust the front/ rear balance to suit venue,
tyres and weather conditions. It's not that difficult to do and is surely
the only worth while set up for a track car. I think that with any other
arrangement you are going to leave easily achievable gains "on the table".
One other point to note concerning really heavy braking.
The front uprights/ stub axles on the Triumph were prone to flexing under
heavy braking causing the discs to push the pads back into the calipers
and this caused very long pedal travel before the brakes "bit".
I put in low pressure retaining valves in the front brake lines to deal with
this pad knock back effect. Do 928s ever suffer from this problem?
The Parts Whisperer
IIRC, it's a steel bar assembly that's welded where the pedal pad hangs on. There's a room on your right there, through the door past Tom, where there are known to be a few spare parts for these cars. Take a look at a pedal and see. I've fabricated adjustable pedals and arms before, and it isn't rocket science by any stretch.
The Parts Whisperer
The Parts Whisperer
